Can't find "Add Library" button in settings
I want to add a library for the Plex Home PC server, but there’s no “Add Library” tab. Please tell me how to enable that tab. This is my admin account and I did installed Plex Media Server.
I cannot see your image above, but normally at your home screen you select more, and the plus sign next to your server’s name and the window pops up:
Is your server running? From your picture it looks like there is no server running.
If a server is running or linked to your account. You would see Right under where is says “Plex for windows” in your picture it should have the name of your server and then under that there will be “Status” and then “Settings”. Under Settings you then go to “library” and you can add from there.
Based on the picture you provided it looks like there is no server.
Thank you for the feedback but I solved it myself. The problem was my account couldn’t connected to media server I installed. So I deleted all plex registry and reinstalled the server. It solved everything.
