Can't Login
Server Version#: 1.41.9
Jul 20, 2025 03:26:25.293 [140608536640312] DEBUG - WebSocket: client initiated close
Jul 20, 2025 03:26:25.294 [140608534530872] DEBUG - NotificationStream: Removing because of close
Jul 20, 2025 03:26:25.294 [140608534530872] DEBUG - handleStreamRead code 1: stream truncated
Jul 20, 2025 03:26:25.294 [140608534530872] DEBUG - Completed after connection close: [192.168.1.2:57060] -3 GET /:/websockets/notifications (4 live) #14a TLS GZIP 323402ms 100 bytes
Jul 20, 2025 03:26:31.612 [140608536640312] DEBUG - Request: plaintext connection from 192.168.1.2:57329 rejected because secure connections are required
Jul 20, 2025 03:26:39.478 [140608534530872] DEBUG - Request: plaintext connection from 192.168.1.2:57337 rejected because secure connections are required
Jul 20, 2025 03:26:43.692 [140608547085112] DEBUG - Shutting down with signal 15 (Terminated)
Jul 20, 2025 03:26:43.692 [140608547085112] DEBUG - Ordered to stop server.
Jul 20, 2025 03:26:43.692 [140608547085112] DEBUG - [JobRunner] Job running: /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/CrashUploader --sessionStatus=exited --sessionStart=1753006211 --sessionDuration=992 --version=1.41.9.9961-46083195d --userId=(MASKED) --sentryUrl=https://o17675.ingest.sentry.io/api/1233455/ --sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Jul 20, 2025 03:26:43.699 [140608547085112] DEBUG - [JobRunner] Jobs: Starting child process with pid 15817
Jul 20, 2025 03:26:43.699 [140608551819920] DEBUG - Stopping server…
Jul 20, 2025 03:26:43.699 [140608551819920] DEBUG - HttpServer: Stopping server.
Jul 20, 2025 03:26:43.700 [140608511036216] DEBUG - TranscodeJobManager: [Running] onServerShutdown
Jul 20, 2025 03:26:43.700 [140608511036216] DEBUG - TranscodeJobManager: [Running] → [Shutdown]
Jul 20, 2025 03:26:43.700 [140608476334904] DEBUG - MetadataItemClusterRequestHandler: a shutdown event has been received
Jul 20, 2025 03:26:43.700 [140608551819920] DEBUG - Server stopped.
Jul 20, 2025 03:26:43.700 [140608551819920] DEBUG - NetworkService: Stopping advertisement.
Jul 20, 2025 03:26:43.700 [140608495319864] ERROR - Network Service: Error in advertiser handle read: 125 (Operation canceled) socket=74
Jul 20, 2025 03:26:43.700 [140608551819920] DEBUG - Killing plug-ins.
Jul 20, 2025 03:26:43.709 [140608547085112] DEBUG - Jobs: ‘/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/CrashUploader’ exit code for process 15817 is -6 (signal: Aborted)
Jul 20, 2025 03:26:43.736 [140608551819920] DEBUG - [com.plexapp.agents.imdb] Killing.
Jul 20, 2025 03:26:43.745 [140608547085112] WARN - JobManager: Could not find job for handle 11773
Jul 20, 2025 03:26:43.748 [140608551819920] DEBUG - [com.plexapp.system] Killing.
Jul 20, 2025 03:26:43.754 [140608547085112] WARN - JobManager: Could not find job for handle 10338
Jul 20, 2025 03:26:43.762 [140608551819920] DEBUG - ChildProcessMonitor: Waiting for Plex Tuner Service to exit.
Jul 20, 2025 03:26:43.762 [140608551819920] DEBUG - [JobRunner] Signalling job ID 11734 with 2
Jul 20, 2025 03:26:43.800 [140608495319864] INFO - Network Service: Abandoning advertise socket, it was closed.
Jul 20, 2025 03:26:43.827 [140608547085112] DEBUG - Jobs: ‘/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Tuner Service’ exit code for process 11734 is 0 (success)
Jul 20, 2025 03:26:43.827 [140608491100984] DEBUG - [ChildProcessMonitor] Plex Tuner Service exited.
Jul 20, 2025 03:26:43.833 [140608551819920] DEBUG - Job was already killed, not killing again.
Jul 20, 2025 03:26:43.833 [140608551819920] DEBUG - Database: Shutting down.
Jul 20, 2025 03:26:43.910 [140608551819920] DEBUG - Database: Shutting down.
I have reset my Qnap Nas a couple days ago. I am not able to access to Plex Media Server thru IP address. no media available on mobile app. please help!
Really difficult to tell what’s happening here from a snippet showing normal shutdown.
Given you can’t login, and you reset the QNAP’s network configuration.
  1. Does the QNAP’s DNS and Gateway IPs point to your modem/router IP?
  2. In the remote chance the server isn’t claimed, have you tried to open PMS using a Private (incognito) browser window? (The browser will keep cookies from the previous instance. Incognito mode ignores them)
I can see, at plex.tv, where you recreated the server instance overnight.
Once you’ve gotten back into the server and confirmed it’s properly reclaimed,
  1. Check the manual port forwarding you have configured in your modem/router (PMS reporting stable remote access)
  2. Restart all the mobile apps (They will continue to look for the old server instance until restarted – which is when they update the list of server ids)
