Can't play media to web player since upgrade to 0.9.17.2
I recently upgraded to plex server 0.9.17.2 (plexmediaserver_0.9.17.2.2159-2bd156c_amd64) and have since been unable to stream media, when I look in the logs it claims there is an issue with the trancoder
Jun 14, 2016 17:02:17.226 [0x7fbb52ff7700] ERROR - Unexpected error configuring transcoder: locale::facet::_S_create_c_locale name not valid
Does anyone know a solution before I downgrade?
Logs attached
server: hp micro gen8
linux debian jessie os
Update: Won’t stream to webplayer but will stream to android app
Same on Windows 0.9.17.2. Some Media work some not seems to be a Problem with 0.9.17.2. After downgrade it works again praise VM Backups!
Logs attached
If you search the forum for this error or parts of the error, you should find the answer
This is expected to be fixed in the next release and is an issue when the system locale differs from what the plexmediaserver.service file has the locale set to
To overcome the problem. edit the service file /etc/systemd/system/plexmediaserver.service to have the same Language / Locale values set as the OS’s locale settings and then run: systemctl daemon-reload and restart Plex Media Server
Very unlikely - in fact, cannot be the same issue.
Please enable debug logging on the server and restart the server and when you get the problem. find the Plex Media Server.log and upload it in a new forum topic on the Plex Media Server Preview Releases forum
See
https://support.plex.tv/hc/en-us/articles/201643703-Reporting-issues-with-Plex-Media-Server
https://support.plex.tv/hc/en-us/articles/200250417
