Can't scan for channels
Have not been able to find anything yet that explains it
It appears that Plex Media Server.exe is able to run this
C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe
but not
C:\Program Files (x86)\Plex\Plex Media Server\Plex Tuner Service.exe
or this
C:\Program Files (x86)\Plex\Plex Media Server\Plex DLNA Server.exe
Could you see if they got quarantened by antivirus / defender
you have this running MsMpEng.exe and also SmartScreen.exe
Explore these two - may be look at How to fix ‘This app has been blocked for your protection’ prompt on Windows 10 PC | Windows Central
PS: I am back on Monday
I don’t know, I disabled smart screen and real-time protection and anything else security related. Restarted Plex Media Server as admin and still had the problem. I guess my next step is to backup my database and build a new server and see what happens. Very odd.
I scanned with Malwarebytes to see if there was some sort of infection and it found nothing, which is expected since I don’t do anything with this box except for run Plex.
Thanks for the help anyway
It is strange that this can be run by Plex Media Server
but not these two
What shows in Windows Defender Firewall Advanced Settings under “Monitoring → Firewall” view for these - Should have an “Allow” for each
Does the “Virus and threat protection” view (Run/Virus and threat protection ) show anything? eg in Protection History
You can try a repair of the Installation of Plex Media Server through Add or Remove Programs - or uninstall and re-install - installing latest beta. and see if we still get the Access Denied error logged in the Plex Media Server log
ERROR - [ChildProcessMonitor] Jobs: failed to start child process C:\Program Files (x86)\Plex\Plex Media Server\Plex Tuner Service.exe: CreateProcessW(omitBinary ? NULL : (LPCWSTR)pathify(job->binary).c_str(), (LPWSTR)utf8to16(cmdLine).c_str(), NULL, NULL, TRUE, dwCreationFlags, (LPVOID)env.c_str(), !m_workingDirectory.empty() ? m_workingDirectory.c_str() : NULL, &si, &processInfo): Access is denied.
I currently have the firewall off:
Protection history doesn’t have much:
I have done an uninstall and re-install recently, but it didn’t help. That’s why I said I might just have to build a new server and backup and restore my PMS database. I may try running these manually and see what I get:
