This is a continuation of this thread:
I have the same issue here on a brand new install on a win 7 machine. The problem is I cannot chose the correct guide channel in the manage channel dialog box. I have this problem on a number of channels but for these pictures, channel 35.1 is the one I’m focusing one.
The hdhr correctly identifies the channel as 35.1 wofl-dt.
Plex correctly lists the channel as 35.1 and has the correct station name in the device channels column. However wofl-dt does not show up in the guide channels pulldown. The only option I have for channel 35.1 is wspf.
This means that the channel guide data for this channel is incorrect and I can’t schedule recordings for this channel.
I have this problem for a number of channels, but 35.1 (local fox station) is the only one that is really an issue and prevents me from using the plex dvr.
Thanks!
