Channel list f.. up
since the update the channel list is totally fucked up.
I know plex usually ignores complaints but i let stream out.
Now plex identifies Channels wrong or do not even have the station in that over blow channel list.
YOU NEED TO FIX THAT !!! otherwise LIve TV / DVR is usless
I have this problem too. On “Manage Channels,” the “Device Channels” are correctly identified, but some of the “Guide Channels” are wrong. This of course means that the TV Guide for those channels is incorrect, and I can’t record anything on them. Any ideas? I’m running HDHomeRun Connect and MacMini running 10.14.4. Thanks.
Same here after the latest update that mentioned that a fix or change with the guide data. Rolling back to prior version of Plex does not correct. All the channels were wrong in the guide. Deleting the DVR and re-adding seemed to resolve the issue for me.
