Channel Guide data is wrong.
The issue I am having is when I add my channels my HD Home run detects the channel has 2.1 WMAR-HD but it wants to set it to Guide channle 2.1 WMARDT (ABC) which is not correct. It needs to be WMARHD. So all the guide data is wrong. Does anyone know a way to fix this?
This has nothing to do with Plex don’t worry about it and root problem lays at gracenote there channel ID don’t always match the broadcast channel ID as I have channel ID that are wrong as well.
The main problem is not the label that shows but the Guide Data is wrong.
Take look at Titantv Guide dose it match what in Plex ?.
My 12.1 is also showing up incorrect, so my shows from that channel are not recording. This I believe needs to be fixed with Gracenote, but they need a developer to tell them as they don’t take issues from the community.
