Server Version#:1.19.4.2865
Player Version#: 1.11.0.1215-1d8c460c
I can’t select the original quality and select quality higher than 720p. In addition, when I click on “Show All”, nothing happens.
Any clue about this?
Thanks in advance,
Arsène Lapostolet
That’s because either
the client has only a relay connection to the server (which is limited to a bandwidth maximum of 2mbps for Plex Pass holders)
the server has set a limit of 2 mbps for each outgoing remote stream
If the client is sitting in the same local network as the server, it might have issues with DNS or ‘DNS rebinding protection’. https://support.plex.tv/articles/206225077-how-to-use-secure-server-connections/
Another thing to check: if the server is running inside a “container” or “virtual machine”, it should use the network connection of the “host” and not a “NAT’ed” connection.
Ok I see, thank you for your answer !
system
Closed
August 26, 2020, 6:05pm
4
