Can't stream to Sonos devices...thinks stream size is 2147483647
I am trying to get Sonos to play my plex music library. I have an old S1 and Play3…
They both see everything fine, but when I play, I see in the logs it thinks the stream is huge. (I love when that number makes it itself known…max int)
[Req#57d68f/Transcode] Streaming Resource: Bandwidth exceeded: 2147483647 kbps > 8000000 kbps
So the server is thinking it can be played, or the client device. I have tried a wide variety of settings…changing the max bandwidth,(can’t save it high enough)… but like, it shouldnt be this hard.
Anyone have a fix? I can’t find anything.
See SONOS not playing specific files
Do you have “Perform extensive media analysis during maintenance” (Settings > Scheduled Tasks) enabled for your server?
See SONOS not playing specific files - #40 by Volts for forcing deep analysis from the CLI.
Enabled it, tried on a couple of songs and it works. Can’t believe it finished my 3TB library already though
