Server Version#: 1.19.1.2645
Player Version# Web Player: Versie 4.31.1
Don’t know what log files are required.
Hi
When i’m watching serie’s via Plex Web Player i normally can view them in original quality but on some serie’s i can’t do it and its slows the stream down.
It has to buffer allot and when i’m playing it on original quality it goes fast without any buffering.
Video file info:
Codec HEVC
Bitrate 6840 kbps
Bit Depth 10
Chroma Subsampling 4:2:0
Coded Height 1080
Coded Width 1920
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 50 fps
Height 1080
Niveau 4.1
Profiel main 10
Ref Frames 1
Width 1920
Display Title 1080p (HEVC Main 10)
Codec EAC3
Kanalen 6
Bitrate 768 kbps
Taal English
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Titel English
Display Title English (EAC3 5.1)
What could be the problem?
You can’t play that file in Plexweb.
(you’re using the hosted Plexweb at Plex.tv - for some reason)
Use Plex for Windows (Apps and Devices link at the bottom of this page).
or
Plex Media Player:
Plex Media Player v2.54.0 is now available to all macOS and Windows users.
DOWNLOADS:
macOS
Windows
NEW:
TV layout is now default
FIXED:
Bumped Desktop layout revision to correct ad playback issues
Fixed focus sometimes being lost in preplay pages
Fixed extended info details missing line breaks
Fixed an issue that could cause incorrect translations in stream title selection menu items
JuiceWSA:
a
Thanks for the quick respons.
I use the web browser because i watch at different places and i don’t wanne install the app or player every time again.
The browser is just easy to access.
But on the media player i can watch that serie in original quality, so maybe it can be fixed on the web player to?
Kind regards
No it cannot be fixed on the web player. The web browser uses the native player which does not play that file. If you want to play those sorts of files, you’re going to need a desktop app.
okey thanks alot for the info, it has been fixed with the desktop apps
i just saw that my other serie also is mkv type. the only defference is the video codec
Codec H264
Bitrate 9075 kbps
Bit Depth 8
Chroma Location left
Coded Height 1088
Coded Width 1920
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 23.976 fps
Height 1080
Niveau 4.0
Profiel high
Ref Frames 4
Scan Type progressive
Width 1920
Display Title 1080p (H.264)
Codec EAC3
Kanalen 6
Bitrate 192 kbps
Taal English
Right. MKV is merely a container, the dealbreaker is the video encoding.
okey thanks for the extra info ^^
in the future i’ll try not to get HEVC/H-265 video codec
system
Closed
July 9, 2020, 9:38am
9
