Cast doesn't work on Android starting 3.4.6
It looks like the casting changes in Plexamp 3.4.6 on Android broke casting for me, for groups and individual speakers alike. I’m on Android 12 B1 on a Pixel 5, and I’m pretty sure the beta OS didn’t break this - but I can’t swear on that timing :slight_smile: I have various Nest and non-Google devices, neither of them works with Plexamp, but they all work with Spotify or YTMusic.
My logs are like this, a bit redacted
May 24, 2021 08:47:03.302 [Javascript] WARNING - DEVICE: Player connection https://...d153fb3c8.plex.direct:10157 didn't work for Chrome: HTTP status -28
May 24, 2021 08:47:03.302 [Javascript] WARNING - DEVICE: Connection testing failed for Chrome
May 24, 2021 08:47:03.495 [Javascript] INFO - Cast: Session started.
May 24, 2021 08:47:03.496 [Javascript] INFO - Cast: Starting channel.
May 24, 2021 08:47:03.536 [Javascript] INFO - Cast: Successfully connected to cc80b89f...
May 24, 2021 08:47:03.536 [Javascript] INFO - Audio Route: Switched over to player Both Speakers (volume: NaN).
May 24, 2021 08:47:03.536 [Javascript] WARNING - DEVICE: No provider for source e77fe7527b2...
May 24, 2021 08:47:03.537 [Javascript] WARNING - DEVICE: No provider for source e77fe7527b2...
May 24, 2021 08:47:03.537 [Javascript] WARNING - Cast: Could not find server e77fe7527b2... (exists: false).
May 24, 2021 08:47:03.537 [Javascript] INFO - Audio Route: Play failed.
May 24, 2021 08:47:03.537 [Javascript] INFO - Cast: Sending message 'STOP'.
May 24, 2021 08:47:03.537 [Javascript] WARNING - Audio Route: Error switching player to Both Speakers.
May 24, 2021 08:47:03.544 [Javascript] INFO - TypeError: Cannot read property 'clientIdentifier' of null
May 24, 2021 08:47:03.648 [Javascript] INFO - Cast: unknown player state.
May 24, 2021 08:47:03.750 [Javascript] INFO - Cast: unknown player state.
May 24, 2021 08:47:04.009 [Javascript] INFO - Audio: Not processing state update of stopped for track .
As a comparison data point, I’m running Android 11 patch level RQ2A.210505.002 on a Pixel 4a, PlexAmp 3.4.6. I was just able to cast to a Google Nest speaker. I’ll do some additional testing to see if I can create a failure scenario.
Thanks, that was a good data point! I uninstalled, installed 3.4.5, that worked, and the updated to 3.4.6 again, and now cast works again. Must have been something weird cached…
