Certificate issue. Server indicates “Fully Accessible…” but app.plex.tv and remote can not connect
Server Version#: v1.32.8.7639
Player Version#:1.81.0
As stated. Server indicates all is well with remote access, local access is good. However, neither app.plex.tv nor any remote clients can connect to the server.
I previously had a custom certificate and removed it a while ago. This is the first time I have tried to connect remotely in a while. I have a feeling it’s a Plex certificate issue. Not sure where to look. This is more difficult to troubleshoot because I am accessing the server remotely using VNC.
When trying to connect remotely I am shown two servers when I only have one that is currently authorized in authorized devices. One of the servers I deleted months ago when I moved to a new server.
Also it should be noted that I can’t connect Infuse player to the Plex server when Security is set to required instead of preferred.
john@Mac-mini:~/Library/Caches/PlexMediaServer$ls -aleo
total 152
drwxr-xr-x@  15 john    480 Nov 10 14:26 .
drwx------+  98 john   3136 Nov 10 14:20 ..
 0: group:everyone deny delete
-rw-r--r--@   1 john   6148 Nov 10 14:26 .DS_Store
-rw-r--r--@   1 john   6368 Nov 10 14:20 CloudAccessV2.dat
-rw-r--r--@   1 john  12176 Nov 10 14:20 CloudAccountV2.dat
-rw-r--r--@   1 john   5536 Nov 10 14:26 CloudUsersServices.dat
-rw-r--r--@   1 john    896 Nov 10 14:20 CloudUsersSubscriptionsV2.dat
-rw-r--r--@   1 john    848 Nov 10 14:20 CloudUsersV2.dat
-rw-r--r--@   1 john  11168 Nov 10 14:20 Flags.dat
drwxr-xr-x@   3 john     96 Nov  9 02:04 OCSP
drwxr-xr-x@ 259 john   8288 Nov 10 14:25 PhotoTranscoder
-rw-r--r--@   1 john   7920 Nov 10 14:20 Privacy.dat
drwxr-xr-x@   5 john    160 Nov 10 14:25 Transcode
-rw-r--r--@   1 john    384 Nov 10 14:20 UpdateChannels.dat
-rw-------@   1 john   4560 Oct 20 13:31 cert-v2.p12
Plex Media Server.1.log (154.0 KB)
PlexDebugInfo-FebruaryMan-8.27-7223 (2023-11-10 17.20.30 -0600).zip (844.5 KB)
@ChuckPa
Anyone? The other thread regarding resetting certificates is closed.
Should I just delete everything and start from scratch?!
@John_001
Just saw you here. Sorry for the delay.
This is a network configuration issue.
You got two network cables on the same subnet plugged in – PMS is confused.
Nov 09, 2023 19:31:59.108 [0x16bcb3000] DEBUG - Transcoder: Cleaning old transcode directories.
Nov 09, 2023 19:31:59.108 [0x16bcb3000] DEBUG - NetworkInterface: Notified of network changed (force=0)
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG - Detected primary interface: 0.0.0.0
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG - Network interfaces:
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG -  * 1 lo0 (127.0.0.1) (00-00-00-00-00-00) (loopback: 1)
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG -  * 1 lo0 (::1) (00-00-00-00-00-00) (loopback: 1)
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG -  * 6 en0 (fdb2:14c4:15bb:4342:1016:e5ad:d123:eed2) (5C-1B-F4-92-3A-3E) (loopback: 0)
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG -  * 6 en0 (192.168.10.143) (5C-1B-F4-92-3A-3E) (loopback: 0)
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG -  * 11 en4 (192.168.5.1) (00-24-27-09-09-87) (loopback: 0)
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG -  * 13 en1 (192.168.10.144) (5C-1B-F4-97-B1-C0) (loopback: 0)
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG -  * 13 en1 (fdb2:14c4:15bb:4342:14c3:abf3:58df:d5fd) (5C-1B-F4-97-B1-C0) (loopback: 0)
Nov 09, 2023 19:31:59.109 [0x16bcb3000] DEBUG - Activity: registered new activity c5b8ebe5-0928-4c55-a698-6c007ff5701b - "Processing subscriptions"
Nov 09, 2023 19:31:59.110 [0x16bcb3000] DEBUG - Creating NetworkServices singleton.
  1. PMS will favor en0 over en1 but that’s still shaky and not proper.
  2. You want one adapter per subnet. Unplug one :slight_smile:
Cert wise, It looks like you just recreated a new server instance?
I’m sorry i didn’t get here in time.
Thank you. I appreciate your response.
I have a thunderbolt to 10g Ethernet adapter on 192.168.5.1 subnet 255.255.255.0
I have the built in Ethernet adapter on 192.168.10.143 subnet 255.255.255.0
Aren’t those two different subnets? I am genuinely asking - still learning.
I removed the current server, added it again but renamed it slightly.
I also turned relay on and off. Turned off manual port. Changed router settings. Turned off DNS Rebinding protection. Turned on UPnP.
I’m also have 192.168.10.143 selected as preferred in Plex settings.
Apple allows WiFi and Ethernet to remain active at the same time on a device.
