Change Plex DVR Default Folder
I want Plex to record TV Shows to a temp location, so at midnight my system can execute MCEBuddy transcoding/encoding to all the daily recorded files. I do this to ensure my files are all named properly but most of all I use MCEBuddy to remove all the commercials. Then once all the files are done, MCEBuddy will move them to my “TV Shows” folder on my 17tb external drive, where Plex is looking for “TV Shows”.
So…how can I change the default folder?
Any answer on this? This is exactly what I am trying to do.
looking for the same.
