Change Default Directory for Recorded TV
How (where?) do I change where Plex stores my Recorded TV (off of my HDHomeRun)? I want to move this default to a larger/faster drive.
There is no default as such.
The target library and folder are stored in the recording job.
Step 1: add the new drive/folder as a source to your DVR library
Step 2: edit each recording job in the DVR Schedule and modify its target folder
P.S. add a small .txt file to the new target folder, to signal to Plex that it is working correctly.
Thank you! That is exactly what I needed. :grinning:
