Change to winter time and incorrect display of programs
Server Version#: 1.24.5.5173
Player Version#: 4.63.0
Tuner Make/Model: Enigma2
Guide/Lineup name: xTeve
Using XMLTV?: Yes
Channel number/Name: All
I have a problem. Unfortunately, the time in Poland has changed from summer to winter. After this change, Plex is showing me the timing of the EPG programs incorrectly.
EPG I create myself with xTeve, here is its code:
      <programme channel="1000" start="20211124042000 +0100" stop="20211124050500 +0100">
          <title lang="pl">Przysięga</title>
          <title lang="en">Yemin</title>
          <desc lang="pl">Po śmierci matki mieszkająca na wsi Reyhan (Özge Yagiz) jest zdana na siebie. Dziewczynę odwiedza przybrany wuj, bogaty biznesmen Hikmet (Berkant Müftüler), i namawia do ślubu ze swoim synem Emirem (Gokberk Demirci). Początkowo niechętna, młoda kobieta zostaje niejako zmuszona do złożenia obietnicy, że wyjdzie za nieznajomego mężczyznę.(n)</desc>
The program should be at 04:05 and unfortunately it shows up at 03:05. Sometimes it helps to manually refresh the DVR, but you don’t want to do it manually every day. Is it possible to correct this?
