Changing location of my media server
I’m using flex to store my movies. Ive worked hard to add art of the movies that system didn’t recognize. I’m planing to copy all movies to a different external hard rive and connect it to a different computer (Mac).
the question - will I need to start from scratch to build the artwork or will it be automatically there ?
Do you mean you will run PMS on this new Mac? If so then that will be treated as a new server. PMS is specific to the computer where it is running. It doesn’t matter where your media is.
If you want to keep all your setting, follow this guide, https://support.plex.tv/articles/201370363-move-an-install-to-another-system/.
