Changing Playback Video Quality Causes Transcoder To Die
Server Version#: 1.40.5.8921
Player Version#: Plex Web 4.137.1
When I playback some media it will start fine but when I change the video quality, it gets stuck on a black screen.
I did some troubleshooting and this is what I found
  • The issue is present on H265 media only. Tested on H264 media and the quality changes as expected, no issues.
  • Only happens when using hardware transcoding. Turning off hardware acceleration in the server settings fixes the issue. However this defeats the purpose of having a GPU in my server in the first place.
  • Checking the logs reveals the following lines that is most likley related to this issue:
[Req#5a06/Transcode] Transcoder: Failed to delete session directory (boost::filesystem::remove: Directory not empty [system:39]: "/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-ghf9xidqh1e7pg7uwo9ep8k9-e722aadd-5588-4d5c-870c-5a066382dae8")
Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 2710 is -9 (signal: Killed)
[Req#6086/Transcode/ghf9xidqh1e7pg7uwo9ep8k9] Transcode runner appears to have died.
  • I have also changed the transcoder temporary directory to somewhere else (outside the docker container) which does not make a difference. Same log messages show up.
  • I also tried using /dev/shm as the transcoder temporary directory which also fails however the transcoder process simply dies without any error message such as the one described earlier.
  • Checking the directory indicated in the log entry is empty.
  • Changing the quality on the Plex Desktop App yields a playback error - An unknown error occurred (4294967283), Error code: 4294967283. However after clicking retry it will start playing again at the requested quality and transcoding works again.
  • Changing the quality on the Plex iOS app does not have this issue.
Using NVIDIA driver 560.35.03 with GTX 1050 Ti running under unraid 6.12.11.
plex_server.log (489.4 KB)
I am having this same issue and CANNOT figure it out for the life of me. I though for a long time it was just the drivers getting outdated or using the incorrect version, but after clearing all that away and getting a fresh driver installed it’s still occurring.
Does it work fine on an Android/iOS device? Cause for me it only happens on the web player (as far as I have been able to test). It’s been this way for years. I just tell my users to pick the correct quality before starting the stream in the Plex settings when they use web. That works fine, but changing the quality always stops the stream in different ways. Sometimes a black screen, sometimes an error.
Yeah it seems to be fine on the mobile applications, only on the web player.
I’m also having this issue. Playback intermittently fails when switching quality in the web player and on the macOS app but always works in the iOS app. This only happens with hardware transcoding.
A known problem with Plex Web. May affect other clients as well.
Workaround is to change the quality before starting playback.
Settings → Plex Web → Quality
Exact same issue as well here (Windows/Webclient). The Windows client throws error code 4294967283. Does someone know when this will be fixed?
@lorisTheG
Yes. another “Me too” about the web client. :frowning:
This will be fixed in the rewrite of the web player (which is happening now)
As stated, the minimal viable workaround is to set quality prior to starting playback.
I have explained what’s happening.
I know why it’s happening (looking at all the logs)
The decision made was to address it with the rewrite.
( The amount of work needed to fix it is as much as the fresh new web client )
I am using (testing) the new client and the problem does not exist.
You can change to anything you want (up or down or back up or back down again) without failure.
Is there any previsions on where the new web player will be publicly available?
Is the Windows application also getting the fix? Or just the web client?
@Karbust
We’re getting all new players.
The first being done are the mobile / tablet players.
The desktop players will be take what’s written for the mobile players, change the layout a bit, and tweak for the desktops.
So, until then, changing resolutions in the player is broken, but hardware transcoding (nvidia gpu) is still functional, correct?
