Changing summary's language
Server Version#: 4.133.0
<If providing server logs please do NOT turn on verbose logging, only debug logging should be enabled> I need movies/series summaries to be in spanish but can’t find the setting for that.
There is a language setting in the properties of each Plex library. This determines the language of the titles and the summaries.
https://support.plex.tv/articles/200289266-editing-libraries/
This library default can be overridden for each individual movie (if desired) by editing the movie itself.
If you change either of the above, you may have to subsequently trigger “Refresh Metadata” on either the library or the movie.
