Movie summary displays in wrong language. Fixes when I force a Fix Match with English language specified in Search Options
For the last several months, when I add movies to the library, the Movie summary/plot text will appear in a strange language. English is my preferred lang, and Plex shows this in settings.
I am able to fix this on a case by case basis by selecting Fix Match, and specifying English as the language in Search Options. Weirdly, the default language that appears in the Search Options language drop down box is Bahasa Indonesia (I would have expected English to appear there as it is the default for my system).
Does anyone else have this issue and know of a fix? It’s happening more frequently, and really annoying…
Server Version#: 1.18.2.2058
Player Version#: Not Applicable
Which language/country have you set for this library (Library context menu > Manage Library > Edit...)?
Also… assuming you use the Plex Movie agent… what Country do you have set in the Advanced tab of the library settings?
Holly Cow! It was the Manage library settings - I don’t recall setting it that way, but I’ve changed it - thanks so much. Country setting in the agents setting was correct. I’ll rescan!
