Channel Guide no longer auto-updating
Channel Guide only updates if a manual update is forced. This started after the change in Guide providers. Will this be fixed, or is there a fix that someone can tell me about? I have not seen any updates in any of the forums so far.
Do you get updates after forcing manually? Which country are you in?
Yes…I have to manually run them to get them. I am in the US.
Oh…I am running the latest version (as of today), on a Linux server.
Hmm…I guess this isn’t fixed or working yet. Anyone heard anything about it?
I took a look at my guide and noticed I only had 6 days worth; I did a manual refresh and now I have nearly 13 days worth. That seems like a problem so I’ve reported it – if I hear anything or if there’s a request for more info, I’ll pass it along :slight_smile:
The devs are aware of the problem and are currently looking to fix it.
Thanks for the update.
