Channel list is empty.
ATV3 6.0.2
Windows 7 Server Running PMS 0.9.8.10-*
23:31:20 PlexConnect: started: 23:31:20
23:31:20 PlexConnect: IP_self: 192.168.0.10
23:31:20 DNSServer: started: 23:31:20
23:31:20 DNSServer: ***
23:31:20 DNSServer: DNSServer: Serving DNS on 192.168.0.10 port 53.
23:31:21 WebServer: started: 23:31:21
23:31:21 WebServer: ***
23:31:21 WebServer: WebServer: Serving HTTP on 192.168.0.10 port 80.
23:31:21 WebServer: WebServer: Serving HTTPS on 192.168.0.10 port 443.
23:31:38 PlexAPI: No Response from Plex Media Server
23:31:38 PlexAPI: We failed to reach a server. Reason: [Errno 10061] No connection could be made because the target machine actively refused it
23:31:38 PlexAPI: Servers (local+MyPlex): 0
23:33:06 PlexConnect: Shutting down.
23:33:06 WebServer: Shutting down.
23:33:09 DNSServer: Shutting down.
23:33:09 PlexConnect: shutdown
Any ideia why its being refused, firewall exception is added for both python and PMS.
PMS setting "require authorization" with no MyPlex login on aTV?
The log keeps me wondering... do you have PlexConnect's PlexGDM disabled?
Here is my settings.cfg
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.0.10
enable_plexgdm = True
hosttointercept = trailers.apple.com
port_ssl = 443
enable_webserver_ssl = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
I tried with GDM as "False" and as "True" and i get the same error, as for the aTV its the same with or without login, just tried too. :P
This is strange. I guess you have to provide the PlexConnect.log file... from PlexConnect startup to hitting the trailers app...
My log file contains this:
12:55:41 PlexConnect: started: 12:55:41
12:55:41 PlexConnect: IP_self: 192.168.0.10
12:55:41 DNSServer: started: 12:55:41
12:55:41 DNSServer: ***
12:55:41 DNSServer: DNSServer: Serving DNS on 192.168.0.10 port 53.
12:55:41 WebServer: started: 12:55:41
12:55:41 WebServer: ***
12:55:41 WebServer: WebServer: Serving HTTP on 192.168.0.10 port 80.
12:55:42 WebServer: started: 12:55:42
12:55:42 WebServer: ***
12:55:42 WebServer: WebServer: Serving HTTPS on 192.168.0.10 port 443.
12:56:22 PlexAPI: ***
12:56:22 PlexAPI: looking up Plex Media Server
12:56:23 PlexAPI: GDM: Servers discovered: 1
12:56:24 PlexAPI: No Response from Plex Media Server
12:56:24 PlexAPI: We failed to reach a server. Reason: Internal Server Error
12:56:24 PlexAPI: Servers (local+MyPlex): 1
12:56:35 PlexAPI: No Response from Plex Media Server
12:56:35 PlexAPI: We failed to reach a server. Reason: timed out
12:56:45 PlexAPI: No Response from Plex Media Server
12:56:45 PlexAPI: We failed to reach a server. Reason: timed out
12:56:55 PlexAPI: No Response from Plex Media Server
12:56:55 PlexAPI: We failed to reach a server. Reason: timed out
12:57:05 PlexAPI: No Response from Plex Media Server
12:57:05 PlexAPI: We failed to reach a server. Reason: timed out
12:57:16 PlexConnect: Shutting down.
12:57:16 WebServer: Shutting down.
12:57:17 WebServer: Shutting down.
12:57:17 DNSServer: Shutting down.
12:57:17 PlexConnect: shutdown
Not sure why im getting timeout :/
I hit the aTV "Trailers" button and it opens but stays on "Acessing Trailers" and then nothing more happens.
As for my MPS server i get the error, "myplex cannot connect to the server"
Either your firewall is not correctly configured or you are using a non-standard port for your PMS (change it to the default or change the port in settings.cfg).
The port 32400 is open on my router configuration and my firewall its only the windows one, still cant make this work xD
What is the PMS port set to in the PMS config web manager?
Post screens of your python firewall config please.
What is the PMS port set to in the PMS config web manager? Post screens of your python firewall config please.
Heres the port on the web PMS web manager, its the default one.
[elwf.jpg](http://imageshack.us/photo/my-images/809/elwf.jpg/)
Here you got my Windows firewall allowing python and PMS server.
[vkxg.jpg](http://imageshack.us/photo/my-images/845/vkxg.jpg/)
That doesn’t show me the detail of the Python entry and if you allowed both UDP and TCP traffic, can you post that please?
Can you help me over skype or so doing a new clean installation? Cause this is already a mess xD I can send you the print of my router config, port forwarding with the port open if you want to.
Your router is set up correctly (you can tell because you are signed into MyPlex on your PMS) so I am 90% certain you have not configured your firewall Python rule correctly.
Just post the detail here (double click on the rule).
Thats all i can show you, its Windows Firewall lol.. I gave the most permissions that i can.
[qbci.jpg](http://imageshack.us/photo/my-images/823/qbci.jpg/)
Anyways, after a reboot on router, modem, computers, aTV and all systems involved i could make PMS log into MyFlex server, but i still cant get the channels listing.
Try temporarily disabling the windows firewall.
Just did it right now, still cant get the channels.. Its pretty much all stuff working, except that i cant get the channel listings
Added a couple TVShows from my main computer and i get my locahost stuff in there, just cant get other channels :/
Okay so your movie/TV sections are working?
Do you have the channels show up in e.g. the iOS client?
What are the channels you have loaded?
Yes, check with another Plex client to see if it is a Plexconnect issue. Try Plex/web or the iOS client. I have seen this issue popping up more frequently of late for other clients which indicates a PMS issue.
I added a couple of channels from my iOS Client and i can see em on my aTV, bt as for the channel listing i still dont get nothing.. Where can i know the best channels to watch anime/tvshows/movies/live sports? Been searching here and i added some but some of them dont seem to work properly, maybe they're outdated.
Are you trying to say that your issue is that the channel directory does not show on your ATV?
Related?
https://github.com/iBaa/PlexConnect/issues/194#issuecomment-29562227
