Channel scan and tuning issues
I am having an issue with channel scanning and tuning and looking for help. Here is the setup:
Version: 1.18.2.2058 running on Windows 10 PC
Tuner card: Hauppauge WinTV-HVR-2250 with the latest drivers (Logs show this card as Hauppauge WinTV-7164 BDA ATSC/QAM Tuner)
Service: ImOn Communications cable going straight to tuner card (no set top box)
Issue:
When I do a channel scan, it only finds about 40 channels, most are encrypted, but 10 of them are unencrypted and I can watch those in Plex. I have tried using WinTV8 and NextPVR and I have no problems there. They both find 150+ unencrypted channels, and I can watch them with no issues. Why can’t Plex find all of these channels? Yes, I’ve done multiple channel scans - doesn’t make a difference.
What I’ve done:
I went through the uninstall/reinstall process on each to make sure only one app is using the tuner card. I have looked through the WinTV logs/exports to get the QAM channel/frequency, triplet values for ONID/TSID/SID, etc. for each channel, then used that info to manually setup the channels in Plex without a scan. That was done by taking this WinTV export info and pasting a properly formatted version of it into the XML section of the Plex database using SqlLiteBrowser as discussed on other posts. Yes, that took a while. After that, I was then able to go back into Plex and do the EPG mapping of all 150+ channels. But, when I open the guide and click on the channels, I can’t tune to any of them except for those 10 channels that Plex was able to find on its own during a normal channel scan. On the channels that I can’t watch, the error is “Could not tune channel. Please check your tuner or antenna.” If I have 2 other apps (WinTV and NextPVR) that have ZERO issues finding all of my channels and actually letting me view them, but Plex can’t even find the channels, logic would tell me that there is something wrong with Plex, not my PC, not the tuner card, and not my cable server.
Here are some snippets of the tuner log. Everything looks good up until the SetTuner() line.
WORKING CHANNEL:
Dec 02, 2019 16:46:09.651 [11176] INFO - [I] web_service_t::process_start_channel (device compound_device071dvb#bda#pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#, channel triplet://0:1704:1)
Dec 02, 2019 16:46:09.651 [11176] INFO - [I] device_reactor_t::get_device_list (dvb#bda#pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#)
Dec 02, 2019 16:46:09.651 [11176] INFO - [I] dvb_device_factory_t::get_device_list (dvb#bda#pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#)
Dec 02, 2019 16:46:09.655 [0816] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:46:09.655 [0816] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:46:09.656 [0816] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:46:09.656 [0816] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:46:09.656 [0816] INFO - [I] DeviceGetListEx_impl: pDL->Count:2
Dec 02, 2019 16:46:09.656 [11176] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}, Name Hauppauge WinTV-7164 BDA ATSC/QAM Tuner, Standards 24
Dec 02, 2019 16:46:09.656 [11176] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}, Name Hauppauge WinTV-7164 BDA ATSC/QAM Tuner, Standards 24
Dec 02, 2019 16:46:09.656 [11176] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV-7164 BDA ATSC/QAM Tuner, id dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}, tuners 1, state 0, standards 24
Dec 02, 2019 16:46:09.656 [11176] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV-7164 BDA ATSC/QAM Tuner, id dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}, tuners 1, state 0, standards 24
Dec 02, 2019 16:46:09.659 [11176] INFO - [I] web_service_t::process_start_channel. Trying start channel triplet://0:1704:1 on device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400} (idx 0 out of 2 available)
Dec 02, 2019 16:46:09.659 [11176] INFO - [I] device_manager_t::add_streamer. Channel triplet://0:1704:1, device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}, streamer id 6134af08-a82a-4601-905c-b1c0a6f34cbc
Dec 02, 2019 16:46:09.659 [11176] INFO - [I] device_reactor_t::create_device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Dec 02, 2019 16:46:09.662 [12616] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:46:09.662 [12616] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:46:09.662 [12616] INFO - [I] DeviceGetListEx_impl: pDL->Count:2
Dec 02, 2019 16:46:09.663 [11176] INFO - [I] device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:1704:1 on device device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}.
Dec 02, 2019 16:46:09.665 [11176] INFO - [I] transponder_streamer::start_idle_timer
Dec 02, 2019 16:46:09.665 [11176] INFO - [I] tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 1704, sid 1
Dec 02, 2019 16:46:09.665 [8572] INFO - [I] streamer_container_t::control_thread. Added streamer 6134af08-a82a-4601-905c-b1c0a6f34cbc
Dec 02, 2019 16:46:09.665 [8572] INFO - [I] streamer_container_t::control_thread. First streamer was added. Start program streamer
Dec 02, 2019 16:46:09.665 [8572] INFO - [I] dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:1704:1
Dec 02, 2019 16:46:09.665 [8572] INFO - [I] transponder_streamer::start_channel. Start request for channel triplet://0:1704:1
Dec 02, 2019 16:46:09.666 [8572] INFO - [I] transponder_streamer::stop_idle_timer
Dec 02, 2019 16:46:09.717 [7432] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:46:09.717 [7432] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:46:09.717 [7432] INFO - [I] DeviceGetListEx_impl: pDL->Count:2
Dec 02, 2019 16:46:09.717 [7432] INFO - [I] find_device_by_path. searching for matching tuner with device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Dec 02, 2019 16:46:09.717 [7432] INFO - [I] find_device_by_path. Found device index 0 for device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Dec 02, 2019 16:46:09.717 [7432] INFO - [I] StartDevice() dwDeviceNo:0
Dec 02, 2019 16:46:09.729 [7432] INFO - [I] BDA Device Name: [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:46:09.731 [7432] INFO - [I] add_filter (Hauppauge WinTV-7164 BDA ATSC/QAM Tuner)
Dec 02, 2019 16:46:09.731 [7432] INFO - [I] Tuner identity: vid (1131), pid (7164), subsys (88510070)
Dec 02, 2019 16:46:09.731 [7432] INFO - [I] ret_val: 0
Dec 02, 2019 16:46:09.733 [7432] INFO - [I] add_filter (Microsoft Network Provider)
Dec 02, 2019 16:46:09.757 [7432] INFO - [I] TuningSpace Name: ‘Antenna’ NetworkType: {00000000-0000-0000-0000-000000000000}
Dec 02, 2019 16:46:09.757 [7432] INFO - [I] TuningSpace Name: ‘ATSC’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Dec 02, 2019 16:46:09.757 [7432] INFO - [I] TuningSpace Name: ‘ATSCCable’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Dec 02, 2019 16:46:09.757 [7432] INFO - [I] TuningSpace Name: ‘AuxIn1’ NetworkType: {00000000-0000-0000-0000-000000000000}
Dec 02, 2019 16:46:09.757 [7432] INFO - [I] TuningSpace Name: ‘Cable’ NetworkType: {00000000-0000-0000-0000-000000000000}
Dec 02, 2019 16:46:09.757 [7432] INFO - [I] TuningSpace Name: ‘Digital Cable’ NetworkType: {143827AB-F77B-498D-81CA-5A007AEC28BF}
Dec 02, 2019 16:46:09.758 [7432] INFO - [I] Enumeration found 6 tuning spaces
Dec 02, 2019 16:46:09.758 [7432] INFO - [I] Found TuningSpace
Dec 02, 2019 16:46:09.777 [7432] INFO - [I] GetTunerInterfaces: Pin types (2) :
Dec 02, 2019 16:46:09.777 [7432] INFO - [I] GetTunerInterfaces: Node types (3):
Dec 02, 2019 16:46:09.778 [7432] INFO - [I] GetTunerInterfaces:
Dec 02, 2019 16:46:09.778 [7432] INFO - [I] GetTunerInterfaces: Node interfaces:
Dec 02, 2019 16:46:09.778 [7432] INFO - [I] GetTunerInterfaces: Interfaces on NodeType 0 (2 interfaces):
Dec 02, 2019 16:46:09.778 [7432] INFO - [I] GetTunerInterfaces: {71985F47-1CA1-11D3-9CC8-00C04F7971E0} IID_IBDA_FrequencyFilter
Dec 02, 2019 16:46:09.778 [7432] INFO - [I] GetTunerInterfaces: {1347D106-CF3A-428A-A5CB-AC0D9A2A4338} IID_IBDA_SignalStatistics
Dec 02, 2019 16:46:09.778 [7432] INFO - [I] GetTunerInterfaces: Interfaces on NodeType 1 (1 interfaces):
Dec 02, 2019 16:46:09.778 [7432] INFO - [I] GetTunerInterfaces: {EF30F379-985B-4D10-B640-A79D5E04E1E0} IID_IBDA_DigitalDemodulator
Dec 02, 2019 16:46:09.779 [7432] INFO - [I] GetTunerInterfaces: Interfaces on NodeType 2 (1 interfaces):
Dec 02, 2019 16:46:09.779 [7432] INFO - [I] GetTunerInterfaces: {EF30F379-985B-4D10-B640-A79D5E04E1E0} IID_IBDA_DigitalDemodulator
Dec 02, 2019 16:46:09.779 [7432] INFO - [I] Looking for preferred capture for tuner @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Dec 02, 2019 16:46:09.780 [7432] INFO - [I] Found preferred capture: @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}{b3e3d165-54eb-4b9e-a805-1756644fa400}
Dec 02, 2019 16:46:09.781 [7432] INFO - [I] add_filter (Hauppauge WinTV-7164 BDA Digital Capture)
Dec 02, 2019 16:46:09.785 [7432] INFO - [I] add_filter (Sample grabber)
Dec 02, 2019 16:46:09.790 [7432] INFO - [I] add_filter (MPEG-2 Demultiplexer)
Dec 02, 2019 16:46:09.794 [7432] INFO - [I] add_filter (BDA MPEG2 Transport Information Filter)
Dec 02, 2019 16:46:09.815 [7432] INFO - [I] start_graph: hr=0, state=2
Dec 02, 2019 16:46:09.816 [7432] INFO - [I] StartDevice() OK
Dec 02, 2019 16:46:09.816 [7432] INFO - [I] ----------------------------------------------------------------------------
Dec 02, 2019 16:46:09.817 [7432] INFO - [I]
Dec 02, 2019 16:46:09.817 [7432] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 177000, modulation 0, polarization 0, symbol rate 0, LOF 7, LNB selection signal 0, FEC 0
Dec 02, 2019 16:46:09.817 [7432] INFO - [I] SetTuner() 177000, H, 0 Mod:0 LOF:7 22Khz:0
Dec 02, 2019 16:46:11.740 [8572] INFO - [I] transponder_streamer::tune_transponder_impl. Signal stats: 100, 100, 1
Dec 02, 2019 16:46:11.740 [11176] INFO - [I] web_service_t::process_start_channel. Successfully started channel triplet://0:1704:1 on device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Dec 02, 2019 16:46:11.740 [7948] INFO - [I] tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet://0:1704:1
Dec 02, 2019 16:46:11.740 [7948] INFO - [I] tvs_program_streamer::SetPATScanState. Waiting for PAT…
Dec 02, 2019 16:46:11.741 [1308] INFO - [I] http_streamer_t::send_thread_func: adding http client
Dec 02, 2019 16:46:11.791 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:1704:1
Dec 02, 2019 16:46:11.841 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:1704:1
Dec 02, 2019 16:46:11.883 [7432] DEBUG - [I] required sid 1
Dec 02, 2019 16:46:11.883 [7432] DEBUG - [I] services (10): 7, 8, 1,
Dec 02, 2019 16:46:11.883 [7432] DEBUG - [I] pmt pid found: 48
Dec 02, 2019 16:46:11.892 [7948] INFO - [I] tvs_program_streamer::tuning_thread. Waiting for PMT…
Dec 02, 2019 16:46:11.934 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 48, client triplet://0:1704:1
Dec 02, 2019 16:46:12.086 [7948] INFO - [I] tvs_program_streamer::tuning_thread. PAT and PMT found. Checking CA descriptors
Dec 02, 2019 16:46:12.136 [7948] INFO - [I] tvs_program_streamer::tuning_thread. Start streaming
Dec 02, 2019 16:46:12.148 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 49, client triplet://0:1704:1
Dec 02, 2019 16:46:12.148 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 52, client triplet://0:1704:1
Dec 02, 2019 16:46:12.148 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 53, client triplet://0:1704:1
Dec 02, 2019 16:46:12.148 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:1704:1
Dec 02, 2019 16:46:12.148 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:1704:1
Dec 02, 2019 16:46:12.148 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 16, client triplet://0:1704:1
Dec 02, 2019 16:46:12.148 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 17, client triplet://0:1704:1
Dec 02, 2019 16:46:12.148 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 18, client triplet://0:1704:1
Dec 02, 2019 16:46:12.148 [7432] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 8191, client triplet://0:1704:1
Dec 02, 2019 16:46:12.199 [7948] INFO - [I] tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://0:1704:1
Dec 02, 2019 16:46:12.317 [7432] INFO - [I] CTSStreamWaiter::GetPidToCheck. PID to check 49
Dec 02, 2019 16:46:12.317 [7432] INFO - [I] CTSStreamWaiter::GetVideoPid. Video PID 49
Dec 02, 2019 16:46:12.335 [7432] INFO - [I] CTSStreamWaiter::ProcessStream. Found first not encrypted packet. Start streaming
Then, the tuner logs from a NON-working channel that gives the “Could not tune channel” error:
Dec 02, 2019 16:42:49.323 [11176] INFO - [I] web_service_t::process_start_channel (device compound_device071dvb#bda#pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#, channel triplet://0:1742:2)
Dec 02, 2019 16:42:49.324 [11176] INFO - [I] device_reactor_t::get_device_list (dvb#bda#pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#)
Dec 02, 2019 16:42:49.324 [11176] INFO - [I] dvb_device_factory_t::get_device_list (dvb#bda#pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#)
Dec 02, 2019 16:42:49.329 [6060] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:42:49.329 [6060] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:42:49.330 [6060] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:42:49.330 [6060] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:42:49.330 [6060] INFO - [I] DeviceGetListEx_impl: pDL->Count:2
Dec 02, 2019 16:42:49.330 [11176] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}, Name Hauppauge WinTV-7164 BDA ATSC/QAM Tuner, Standards 24
Dec 02, 2019 16:42:49.330 [11176] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}, Name Hauppauge WinTV-7164 BDA ATSC/QAM Tuner, Standards 24
Dec 02, 2019 16:42:49.330 [11176] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV-7164 BDA ATSC/QAM Tuner, id dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}, tuners 1, state 0, standards 24
Dec 02, 2019 16:42:49.331 [11176] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV-7164 BDA ATSC/QAM Tuner, id dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}, tuners 1, state 0, standards 24
Dec 02, 2019 16:42:49.335 [11176] INFO - [I] web_service_t::process_start_channel. Trying start channel triplet://0:1742:2 on device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400} (idx 0 out of 2 available)
Dec 02, 2019 16:42:49.335 [11176] INFO - [I] device_manager_t::add_streamer. Channel triplet://0:1742:2, device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}, streamer id a534890c-56f8-478a-8394-61a79b623c92
Dec 02, 2019 16:42:49.335 [11176] INFO - [I] device_reactor_t::create_device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Dec 02, 2019 16:42:49.340 [8008] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:42:49.340 [8008] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:42:49.341 [8008] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:42:49.341 [8008] INFO - [I] DeviceGetListEx_impl: pDL->Count:2
Dec 02, 2019 16:42:49.341 [11176] INFO - [I] device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:1742:2 on device device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}.
Dec 02, 2019 16:42:49.343 [11176] INFO - [I] transponder_streamer::start_idle_timer
Dec 02, 2019 16:42:49.344 [11176] INFO - [I] tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 1742, sid 2
Dec 02, 2019 16:42:49.344 [10648] INFO - [I] streamer_container_t::control_thread. Added streamer a534890c-56f8-478a-8394-61a79b623c92
Dec 02, 2019 16:42:49.344 [10648] INFO - [I] streamer_container_t::control_thread. First streamer was added. Start program streamer
Dec 02, 2019 16:42:49.344 [10648] INFO - [I] dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:1742:2
Dec 02, 2019 16:42:49.344 [10648] INFO - [I] transponder_streamer::start_channel. Start request for channel triplet://0:1742:2
Dec 02, 2019 16:42:49.344 [10648] INFO - [I] transponder_streamer::stop_idle_timer
Dec 02, 2019 16:42:49.401 [12992] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:42:49.401 [12992] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:42:49.401 [12992] INFO - [I] DeviceGetListEx_impl: pDL->Count:2
Dec 02, 2019 16:42:49.401 [12992] INFO - [I] find_device_by_path. searching for matching tuner with device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Dec 02, 2019 16:42:49.402 [12992] INFO - [I] find_device_by_path. Found device index 0 for device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Dec 02, 2019 16:42:49.402 [12992] INFO - [I] StartDevice() dwDeviceNo:0
Dec 02, 2019 16:42:49.418 [12992] INFO - [I] BDA Device Name: [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:42:49.420 [12992] INFO - [I] add_filter (Hauppauge WinTV-7164 BDA ATSC/QAM Tuner)
Dec 02, 2019 16:42:49.420 [12992] INFO - [I] Tuner identity: vid (1131), pid (7164), subsys (88510070)
Dec 02, 2019 16:42:49.420 [12992] INFO - [I] ret_val: 0
Dec 02, 2019 16:42:49.430 [12992] INFO - [I] add_filter (Microsoft Network Provider)
Dec 02, 2019 16:42:49.473 [12992] INFO - [I] TuningSpace Name: ‘Antenna’ NetworkType: {00000000-0000-0000-0000-000000000000}
Dec 02, 2019 16:42:49.473 [12992] INFO - [I] TuningSpace Name: ‘ATSC’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Dec 02, 2019 16:42:49.473 [12992] INFO - [I] TuningSpace Name: ‘ATSCCable’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Dec 02, 2019 16:42:49.473 [12992] INFO - [I] TuningSpace Name: ‘AuxIn1’ NetworkType: {00000000-0000-0000-0000-000000000000}
Dec 02, 2019 16:42:49.473 [12992] INFO - [I] TuningSpace Name: ‘Cable’ NetworkType: {00000000-0000-0000-0000-000000000000}
Dec 02, 2019 16:42:49.473 [12992] INFO - [I] TuningSpace Name: ‘Digital Cable’ NetworkType: {143827AB-F77B-498D-81CA-5A007AEC28BF}
Dec 02, 2019 16:42:49.473 [12992] INFO - [I] Enumeration found 6 tuning spaces
Dec 02, 2019 16:42:49.473 [12992] INFO - [I] Found TuningSpace
Dec 02, 2019 16:42:49.498 [12992] INFO - [I] GetTunerInterfaces: Pin types (2) :
Dec 02, 2019 16:42:49.498 [12992] INFO - [I] GetTunerInterfaces: Node types (3):
Dec 02, 2019 16:42:49.498 [12992] INFO - [I] GetTunerInterfaces: Node interfaces:
Dec 02, 2019 16:42:49.499 [12992] INFO - [I] GetTunerInterfaces: Interfaces on NodeType 0 (2 interfaces):
Dec 02, 2019 16:42:49.499 [12992] INFO - [I] GetTunerInterfaces: {71985F47-1CA1-11D3-9CC8-00C04F7971E0} IID_IBDA_FrequencyFilter
Dec 02, 2019 16:42:49.499 [12992] INFO - [I] GetTunerInterfaces: {1347D106-CF3A-428A-A5CB-AC0D9A2A4338} IID_IBDA_SignalStatistics
Dec 02, 2019 16:42:49.499 [12992] INFO - [I] GetTunerInterfaces: Interfaces on NodeType 1 (1 interfaces):
Dec 02, 2019 16:42:49.499 [12992] INFO - [I] GetTunerInterfaces: {EF30F379-985B-4D10-B640-A79D5E04E1E0} IID_IBDA_DigitalDemodulator
Dec 02, 2019 16:42:49.499 [12992] INFO - [I] GetTunerInterfaces: Interfaces on NodeType 2 (1 interfaces):
Dec 02, 2019 16:42:49.499 [12992] INFO - [I] Looking for preferred capture for tuner @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Dec 02, 2019 16:42:49.501 [12992] INFO - [I] Found preferred capture: @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}{b3e3d165-54eb-4b9e-a805-1756644fa400}
Dec 02, 2019 16:42:49.502 [12992] INFO - [I] add_filter (Hauppauge WinTV-7164 BDA Digital Capture)
Dec 02, 2019 16:42:49.509 [12992] INFO - [I] add_filter (Sample grabber)
Dec 02, 2019 16:42:49.518 [12992] INFO - [I] add_filter (MPEG-2 Demultiplexer)
Dec 02, 2019 16:42:49.524 [12992] INFO - [I] add_filter (BDA MPEG2 Transport Information Filter)
Dec 02, 2019 16:42:49.549 [12992] INFO - [I] start_graph: hr=0, state=2
Dec 02, 2019 16:42:49.552 [12992] INFO - [I] StartDevice() OK
Dec 02, 2019 16:42:49.552 [12992] INFO - [I] ----------------------------------------------------------------------------
Dec 02, 2019 16:42:49.552 [12992] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 405000, modulation 0, polarization 0, symbol rate 0, LOF 7, LNB selection signal 0, FEC 0
Dec 02, 2019 16:42:49.552 [12992] INFO - [I] SetTuner() 405000, H, 0 Mod:0 LOF:7 22Khz:0
Dec 02, 2019 16:42:49.553 [12992] WARN - [E] put_TuneRequest()
Dec 02, 2019 16:42:49.553 [12992] WARN - [E] BDASetTuner::tune_request failed
Dec 02, 2019 16:42:49.553 [12992] WARN - [E] SetTuner() failed
Dec 02, 2019 16:42:49.553 [12992] WARN - [E] CTVSStreamSource::IntTuneTransponder. tuner_->SetTuner returned an error
Dec 02, 2019 16:42:49.553 [10648] WARN - [E] tune_transponder. Unable to tune transponder
Dec 02, 2019 16:42:49.553 [10648] WARN - [E] transponder_streamer::start_channel. Tuning stransponder for channel triplet://0:1742:2 failed
Dec 02, 2019 16:42:49.553 [10648] INFO - [I] transponder_streamer::start_idle_timer
Dec 02, 2019 16:42:49.553 [10648] WARN - [E] streamer_container_t::control_thread. program_streamer_->start() failed for streamer a534890c-56f8-478a-8394-61a79b623c92
Dec 02, 2019 16:42:49.554 [11176] INFO - [I] web_service_t::process_start_channel. Trying start channel triplet://0:1742:2 on device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401} (idx 1 out of 2 available)
Dec 02, 2019 16:42:49.554 [11176] INFO - [I] device_manager_t::add_streamer. Channel triplet://0:1742:2, device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}, streamer id a534890c-56f8-478a-8394-61a79b623c92
Dec 02, 2019 16:42:49.554 [11176] INFO - [I] device_reactor_t::create_device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}
Dec 02, 2019 16:42:49.555 [0580] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:42:49.555 [0580] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:42:49.555 [0580] INFO - [I] DeviceGetListEx_impl: pDL->Count:2
Dec 02, 2019 16:42:49.556 [11176] INFO - [I] device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:1742:2 on device device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}.
Dec 02, 2019 16:42:49.558 [11176] INFO - [I] transponder_streamer::start_idle_timer
Dec 02, 2019 16:42:49.558 [11176] INFO - [I] tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 1742, sid 2
Dec 02, 2019 16:42:49.558 [9652] INFO - [I] streamer_container_t::control_thread. Added streamer a534890c-56f8-478a-8394-61a79b623c92
Dec 02, 2019 16:42:49.559 [9652] INFO - [I] streamer_container_t::control_thread. First streamer was added. Start program streamer
Dec 02, 2019 16:42:49.559 [9652] INFO - [I] dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:1742:2
Dec 02, 2019 16:42:49.559 [9652] INFO - [I] transponder_streamer::start_channel. Start request for channel triplet://0:1742:2
Dec 02, 2019 16:42:49.559 [9652] INFO - [I] transponder_streamer::stop_idle_timer
Dec 02, 2019 16:42:49.610 [11604] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:42:49.610 [11604] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#
Dec 02, 2019 16:42:49.610 [11604] INFO - [I] DeviceGetListEx_impl: pDL->Count:2
Dec 02, 2019 16:42:49.610 [11604] INFO - [I] find_device_by_path. searching for matching tuner with device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}
Dec 02, 2019 16:42:49.610 [11604] INFO - [I] find_device_by_path. Found device index 1 for device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}
Dec 02, 2019 16:42:49.610 [11604] INFO - [I] StartDevice() dwDeviceNo:1
Dec 02, 2019 16:42:49.616 [11604] INFO - [I] BDA Device Name: [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Dec 02, 2019 16:42:49.617 [11604] INFO - [I] add_filter (Hauppauge WinTV-7164 BDA ATSC/QAM Tuner)
Dec 02, 2019 16:42:49.617 [11604] INFO - [I] Tuner identity: vid (1131), pid (7164), subsys (88510070)
Dec 02, 2019 16:42:49.617 [11604] INFO - [I] ret_val: 0
Dec 02, 2019 16:42:49.618 [11604] INFO - [I] add_filter (Microsoft Network Provider)
Dec 02, 2019 16:42:49.629 [11604] INFO - [I] TuningSpace Name: ‘Antenna’ NetworkType: {00000000-0000-0000-0000-000000000000}
Dec 02, 2019 16:42:49.629 [11604] INFO - [I] TuningSpace Name: ‘ATSC’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Dec 02, 2019 16:42:49.629 [11604] INFO - [I] TuningSpace Name: ‘ATSCCable’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Dec 02, 2019 16:42:49.629 [11604] INFO - [I] TuningSpace Name: ‘AuxIn1’ NetworkType: {00000000-0000-0000-0000-000000000000}
Dec 02, 2019 16:42:49.629 [11604] INFO - [I] TuningSpace Name: ‘Cable’ NetworkType: {00000000-0000-0000-0000-000000000000}
Dec 02, 2019 16:42:49.629 [11604] INFO - [I] TuningSpace Name: ‘Digital Cable’ NetworkType: {143827AB-F77B-498D-81CA-5A007AEC28BF}
Dec 02, 2019 16:42:49.629 [11604] INFO - [I] Enumeration found 6 tuning spaces
Dec 02, 2019 16:42:49.629 [11604] INFO - [I] Found TuningSpace
Dec 02, 2019 16:42:49.642 [11604] INFO - [I] GetTunerInterfaces: Pin types (2) :
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] GetTunerInterfaces:
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] GetTunerInterfaces: Node types (3):
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] GetTunerInterfaces: Node interfaces:
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] GetTunerInterfaces: Interfaces on NodeType 0 (2 interfaces):
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] GetTunerInterfaces: {71985F47-1CA1-11D3-9CC8-00C04F7971E0} IID_IBDA_FrequencyFilter
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] GetTunerInterfaces: {1347D106-CF3A-428A-A5CB-AC0D9A2A4338} IID_IBDA_SignalStatistics
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] GetTunerInterfaces: Interfaces on NodeType 1 (1 interfaces):
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] GetTunerInterfaces: {EF30F379-985B-4D10-B640-A79D5E04E1E0} IID_IBDA_DigitalDemodulator
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] GetTunerInterfaces: Interfaces on NodeType 2 (1 interfaces):
Dec 02, 2019 16:42:49.643 [11604] INFO - [I] Looking for preferred capture for tuner @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401}
Dec 02, 2019 16:42:49.644 [11604] INFO - [I] Found preferred capture: @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}{b3e3d165-54eb-4b9e-a805-1756644fa400}
Dec 02, 2019 16:42:49.645 [11604] INFO - [I] add_filter (Hauppauge WinTV-7164 BDA Digital Capture)
Dec 02, 2019 16:42:49.665 [11604] INFO - [I] add_filter (Hauppauge WinTV-7164 BDA Digital Capture)
Dec 02, 2019 16:42:49.672 [11604] INFO - [I] add_filter (Hauppauge WinTV-7164 BDA Digital Capture)
Dec 02, 2019 16:42:49.674 [11604] INFO - [I] add_filter (Sample grabber)
Dec 02, 2019 16:42:49.675 [11604] INFO - [I] add_filter (MPEG-2 Demultiplexer)
Dec 02, 2019 16:42:49.678 [11604] INFO - [I] add_filter (BDA MPEG2 Transport Information Filter)
Dec 02, 2019 16:42:49.697 [11604] INFO - [I] start_graph: hr=0, state=2
Dec 02, 2019 16:42:49.698 [11604] INFO - [I] StartDevice() OK
Dec 02, 2019 16:42:49.698 [11604] INFO - [I] ----------------------------------------------------------------------------
Dec 02, 2019 16:42:49.698 [11604] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 405000, modulation 0, polarization 0, symbol rate 0, LOF 7, LNB selection signal 0, FEC 0
Dec 02, 2019 16:42:49.698 [11604] INFO - [I] SetTuner() 405000, H, 0 Mod:0 LOF:7 22Khz:0
Dec 02, 2019 16:42:49.699 [11604] WARN - [E] put_TuneRequest()
Dec 02, 2019 16:42:49.699 [11604] WARN - [E] BDASetTuner::tune_request failed
Dec 02, 2019 16:42:49.699 [11604] WARN - [E] SetTuner() failed
Dec 02, 2019 16:42:49.699 [11604] WARN - [E] CTVSStreamSource::IntTuneTransponder. tuner_->SetTuner returned an error
Dec 02, 2019 16:42:49.699 [9652] WARN - [E] tune_transponder. Unable to tune transponder
Dec 02, 2019 16:42:49.699 [9652] WARN - [E] transponder_streamer::start_channel. Tuning stransponder for channel triplet://0:1742:2 failed
Dec 02, 2019 16:42:49.699 [9652] INFO - [I] transponder_streamer::start_idle_timer
Dec 02, 2019 16:42:49.699 [9652] WARN - [E] streamer_container_t::control_thread. program_streamer_->start() failed for streamer a534890c-56f8-478a-8394-61a79b623c92
Dec 02, 2019 16:42:49.699 [11176] WARN - [E] web_service_t::process_start_channel. Could not add streamer on any of the potential devices (more requests than tuners available?..)
Dec 02, 2019 16:42:52.137 [3192] INFO - [I] device_manager_t::idle_timer_func. Stream container for channel triplet://0:1742:2 on device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400} is idle. Deleting it.
Dec 02, 2019 16:42:52.181 [3192] INFO - [I] device_manager_t::idle_timer_func. Stream container for channel triplet://0:1742:2 on device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401} is idle. Deleting it.
Dec 02, 2019 16:42:54.343 [11376] INFO - [I] Stopping graph
Dec 02, 2019 16:42:54.376 [12992] INFO - [I] StopDevice()
Dec 02, 2019 16:42:54.559 [11572] INFO - [I] Stopping graph
Dec 02, 2019 16:42:54.572 [11604] INFO - [I] StopDevice()
Dec 02, 2019 16:42:54.591 [12992] INFO - [I] stop_graph: hr=0, state=0
Dec 02, 2019 16:42:54.787 [11604] INFO - [I] stop_graph: hr=0, state=0
Dec 02, 2019 16:42:55.202 [3192] INFO - [I] device_manager_t::idle_timer_func. Device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400} is idle. Unloading it.
Dec 02, 2019 16:42:55.202 [3192] INFO - [I] transponder_streamer::stop_idle_timer
Dec 02, 2019 16:42:55.202 [3192] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Dec 02, 2019 16:42:55.252 [3192] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Dec 02, 2019 16:42:55.252 [3192] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Dec 02, 2019 16:42:55.594 [11376] INFO - [I] transponder_streamer::idle_thread_func finished
Dec 02, 2019 16:42:55.594 [3192] INFO - [I] device_manager_t::idle_timer_func. Device dvb#bda#0#@device:pnp:\?\pci#ven_1131&dev_7164&subsys_88510070&rev_81#4&27b8eae4&0&00e4#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773401} is idle. Unloading it.
Dec 02, 2019 16:42:55.594 [3192] INFO - [I] transponder_streamer::stop_idle_timer
Dec 02, 2019 16:42:55.595 [3192] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Dec 02, 2019 16:42:55.601 [3192] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Dec 02, 2019 16:42:55.601 [3192] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Dec 02, 2019 16:42:55.791 [11572] INFO - [I] transponder_streamer::idle_thread_func finished
Any help is appreciated! My wife and I had free accounts, then we upgraded hers to be a lifetime plex pass user so we can get the remote access and live TV. Everything seems to be working just fine with movies and music. Live TV is being a pain and trying to figure out why it doesn’t like most of the channels.
