Olli
1
Server Version#: 1.24.x - 1.25.9 (since September/November '21 !?)
Player Version#: –
Tuner Make/Model: Fritz!Box 6490 cable
Guide/Lineup name: German / NetCologne
Using XMLTV?: –
Channel number/Name: –
Hello,
since a few month i noticed the Channel re-scan is crashing on some transponders.
Unfortunally in my case on the second transponder.
In my case the scan will find all channels, but when building the XML, there is only the first tranponder listet.
This is my complete Channel-list from a Windows PMS.
Kanalliste.txt (295,0 KB)
The Synology DSM6 shows also
<MediaContainer size="346">
but there are only 9 Channels from the 1st transponder/frequency in the XML-List.
Another example, from an other User - Windows (341 Channels working fine)
media_provider_resources_WIN.txt (230,2 KB)
and also from him, this is found on linux (10 Channels)
media_provider_resources_DSM.txt (6,9 KB)
in both cases it says:
<MediaContainer size="341">
In all cases the XML ends correctly with
</MediaContainer>
As Workaround i copied the XML DB-Cell from Windows PMS to Synology PMS.
There are some other threads with the same/similar problem but still no success since month:
@ChuckPa @sa2000
Olli
2
In other threads and also in my case, I suspect special characters.
For example, the “Ü” on my second transponder.
Channel 10++ in my case
<Channel channelIdentifier="triplet://777:6900:1050" name="Show Turk" origin="TÜRKISCH" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>2</tt><dq>0</dq><dr/><fr>121000</fr><md>0</md><sr>6900000</sr><pl>0</pl><lf>7</lf><l1>0</l1><l2>0</l2><ls>0</ls><pp>0</pp><hz>0</hz><in>0</in><fc>0</fc><t>6900</t><n>777</n><s>1050</s><en>1</en></tunedata> " number="461" drm="1" type="tv" signalStrength="49" signalQuality="0"/>
<Channel channelIdentifier="triplet://777:6900:1100" name="CNN TURK" origin="TÜRKISCH" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>2</tt><dq>0</dq><dr/><fr>121000</fr><md>0</md><sr>6900000</sr><pl>0</pl><lf>7</lf><l1>0</l1><l2>0</l2><ls>0</ls><pp>0</pp><hz>0</hz><in>0</in><fc>0</fc><t>6900</t><n>777</n><s>1100</s><en>1</en></tunedata> " number="458" drm="1" type="tv" signalStrength="49" signalQuality="0"/>
<Channel channelIdentifier="triplet://777:6900:1150" name="Kanal 7 Int" origin="TÜRKISCH" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>2</tt><dq>0</dq><dr/><fr>121000</fr><md>0</md><sr>6900000</sr><pl>0</pl><lf>7</lf><l1>0</l1><l2>0</l2><ls>0</ls><pp>0</pp><hz>0</hz><in>0</in><fc>0</fc><t>6900</t><n>777</n><s>1150</s><en>1</en></tunedata> " number="454" drm="1" type="tv" signalStrength="49" signalQuality="0"/>
<Channel channelIdentifier="triplet://777:6900:1200" name="EuroD" origin="TÜRKISCH" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>2</tt><dq>0</dq><dr/><fr>121000</fr><md>0</md><sr>6900000</sr><pl>0</pl><lf>7</lf><l1>0</l1><l2>0</l2><ls>0</ls><pp>0</pp><hz>0</hz><in>0</in><fc>0</fc><t>6900</t><n>777</n><s>1200</s><en>1</en></tunedata> " number="452" drm="1" type="tv" signalStrength="49" signalQuality="0"/>
<Channel channelIdentifier="triplet://777:6900:1250" name="TV8 Int" origin="TÜRKISCH" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>2</tt><dq>0</dq><dr/><fr>121000</fr><md>0</md><sr>6900000</sr><pl>0</pl><lf>7</lf><l1>0</l1><l2>0</l2><ls>0</ls><pp>0</pp><hz>0</hz><in>0</in><fc>0</fc><t>6900</t><n>777</n><s>1250</s><en>1</en></tunedata> " number="468" drm="1" type="tv" signalStrength="49" signalQuality="0"/>
<Channel channelIdentifier="triplet://777:6900:1300" name="Rai Uno" origin="ITALIENISCH" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>2</tt><dq>0</dq><dr/><fr>121000</fr><md>0</md><sr>6900000</sr><pl>0</pl><lf>7</lf><l1>0</l1><l2>0</l2><ls>0</ls><pp>0</pp><hz>0</hz><in>0</in><fc>0</fc><t>6900</t><n>777</n><s>1300</s><en>1</en></tunedata> " number="442" drm="1" type="tv" signalStrength="49" signalQuality="0"/>
Channel 11 of 2nd example
<Channel channelIdentifier="triplet://61441:10002:50215" name="Türk Müzigi" origin="Kabel Digital" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>2</tt><dq>0</dq><dr/><fr>402000</fr><md>0</md><sr>6900000</sr><pl>0</pl><lf>7</lf><l1>0</l1><l2>0</l2><ls>0</ls><pp>0</pp><hz>0</hz><in>0</in><fc>0</fc><t>10002</t><n>61441</n><s>50215</s><en>1</en></tunedata> " drm="1" type="radio" signalStrength="59" signalQuality="0"/>
In other cases I have seen that the error only starts with the 3rd transponder.
Olli
3
Another example:
<MediaContainer size="887">
<Channel channelIdentifier="triplet://1:1050:30803" name="M+ LaLiga 1 HD" origin="Movistar+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10729000</fr><md>1</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>35</fc><t>1050</t><n>1</n><s>30803</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="93"/>
<Channel channelIdentifier="triplet://1:1050:30804" name="ALQUILER HD" origin="Movistar+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10729000</fr><md>1</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>35</fc><t>1050</t><n>1</n><s>30804</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="93"/>
<Channel channelIdentifier="triplet://1:1050:30805" name="DAZN 1 HD" origin="Movistar+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10729000</fr><md>1</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>35</fc><t>1050</t><n>1</n><s>30805</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="93"/>
<Channel channelIdentifier="triplet://1:1050:30806" name="AXN HD" origin="DIGITAL+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10729000</fr><md>1</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>35</fc><t>1050</t><n>1</n><s>30806</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="93"/>
<Channel channelIdentifier="triplet://1:1050:30807" name="M+COMEDIA HD" origin="Movistar+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10729000</fr><md>1</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>35</fc><t>1050</t><n>1</n><s>30807</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="93"/>
<Channel channelIdentifier="triplet://1:1050:30809" name="LALIGATV BAR" origin="Movistar+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10729000</fr><md>1</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>35</fc><t>1050</t><n>1</n><s>30809</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="93"/>
<Channel channelIdentifier="triplet://1:1050:30815" name="DAZN 2 HD" origin="Movistar+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10729000</fr><md>1</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>35</fc><t>1050</t><n>1</n><s>30815</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="93"/>
<Channel channelIdentifier="triplet://1:1050:30819" name="LA 1 HD" origin="Movisrta+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10729000</fr><md>1</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>35</fc><t>1050</t><n>1</n><s>30819</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="93"/>
<Channel channelIdentifier="triplet://1:1051:28721" name="tagesschau24" origin="ARD" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10743000</fr><md>0</md><sr>22000000</sr><pl>0</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1051</t><n>1</n><s>28721</s><en>0</en></tunedata> " drm="0" type="tv" signalStrength="77" signalQuality="100"/>
<Channel channelIdentifier="triplet://1:1051:28722" name="ONE" origin="ARD" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10743000</fr><md>0</md><sr>22000000</sr><pl>0</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1051</t><n>1</n><s>28722</s><en>0</en></tunedata> " drm="0" type="tv" signalStrength="77" signalQuality="100"/>
<Channel channelIdentifier="triplet://1:1051:28724" name="arte" origin="ARD" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10743000</fr><md>0</md><sr>22000000</sr><pl>0</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1051</t><n>1</n><s>28724</s><en>0</en></tunedata> " drm="0" type="tv" signalStrength="77" signalQuality="100"/>
<Channel channelIdentifier="triplet://1:1051:28725" name="phoenix" origin="ARD" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10743000</fr><md>0</md><sr>22000000</sr><pl>0</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1051</t><n>1</n><s>28725</s><en>0</en></tunedata> " drm="0" type="tv" signalStrength="77" signalQuality="100"/>
<Channel channelIdentifier="triplet://1:1051:28726" name="Test-R" origin="ARD" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10743000</fr><md>0</md><sr>22000000</sr><pl>0</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1051</t><n>1</n><s>28726</s><en>0</en></tunedata> " drm="0" type="tv" signalStrength="77" signalQuality="100"/>
<Channel channelIdentifier="triplet://1:1052:29850" name="DIVINITY" origin="DIGITAL+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10758000</fr><md>0</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1052</t><n>1</n><s>29850</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="86"/>
<Channel channelIdentifier="triplet://1:1052:29851" name="FOX NEWS" origin="FOXNWS" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10758000</fr><md>0</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1052</t><n>1</n><s>29851</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="86"/>
<Channel channelIdentifier="triplet://1:1052:29852" name="BabyTV" origin="DIGITAL+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10758000</fr><md>0</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1052</t><n>1</n><s>29852</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="86"/>
<Channel channelIdentifier="triplet://1:1052:29853" name="M+ LOS OSCAR" origin="Movistar+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10758000</fr><md>0</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1052</t><n>1</n><s>29853</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="86"/>
<Channel channelIdentifier="triplet://1:1052:29854" name="BOING" origin="DIGITAL+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10758000</fr><md>0</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1052</t><n>1</n><s>29854</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="86"/>
<Channel channelIdentifier="triplet://1:1052:29855" name="ENERGY" origin="DIGITAL+" param="<?xml version="1.0" encoding="UTF-8"?> <tunedata><tt>1</tt><dq>0</dq><dr/><fr>10758000</fr><md>0</md><sr>22000000</sr><pl>1</pl><lf>9750000</lf><l1>9750000</l1><l2>10600000</l2><ls>11700000</ls><pp>0</pp><hz>0</hz><in>0</in><fc>86</fc><t>1052</t><n>1</n><s>29855</s><en>1</en></tunedata> " drm="1" type="tv" signalStrength="78" signalQuality="86"/>
</MediaContainer>
But don’t know the reason of stop…
sa2000
4
Fix confirmed using development test build 1.26.1.5742
Fix will get included in the 1.26.1 official release
