Server Version#:
Windows PLEX server was just too much maintenance. Ubuntu runs and never fails. Set BIOS to boot automatically after power failure if you never want to touch it. Run update/upgrade whenever you feel like it.
Buy NUC11ATKC4 $219 (with RAM & SSD)
Load Ubuntu (free) and update/upgrade
Load media local, external, or NAS
Install Plex (free)
Configure NFS (only if using NAS)
a. Configure NAS advertising on your NAS (proprietary to your NAS)
b. Commands (using example IP and locations):
sudo apt install nfs-common
sudo mkdir /mymediafolder
mount -t nfs -o mountvers=3 192.168.1.5:/mnt/NAS/Shares/Share_Drive /mymediafolder
sudo gedit
when text editor opens, go to OPEN and open /etc/fstab and add the following line:
92.168.1.5:/mnt/NAS/Shares/Share_Drive /mymediafolder nfs mountvers=3 0 0
mount /mymediafolder
mount 192.168.1.5:/mnt/NAS/Shares/Share_Drive -
Open PLEX web interface and add libraries
Install kernel
a. Commands:
cd ~
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.16.20/amd64/linux-headers-5.16.20-051620-generic_5.16.20-051620.202204131933_amd64.deb
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.16.20/amd64/linux-headers-5.16.20-051620_5.16.20-051620.202204131933_all.deb
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.16.20/amd64/linux-image-unsigned-5.16.20-051620-generic_5.16.20-051620.202204131933_amd64.deb
wget https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.16.20/amd64/linux-modules-5.16.20-051620-generic_5.16.20-051620.202204131933_amd64.deb
sudo apt install inxi
sudo apt install vainfo
sudo apt install curl
sudo apt install intel-gpu-tools
sudo apt install intel-media-va-driver-non-free libmfx1
sudo apt install intel-media-va-driver-non-free -
Install Intel Compute Runtime
a. Commands:
cd ~
wget https://github.com/intel/compute-runtime/releases/download/22.16.22992/libigdgmm12_22.1.2_amd64.deb
wget https://github.com/intel/intel-graphics-compiler/releases/download/igc-1.0.10988/intel-igc-core_1.0.10988_amd64.deb
wget https://github.com/intel/intel-graphics-compiler/releases/download/igc-1.0.10988/intel-igc-opencl_1.0.10988_amd64.deb
wget https://github.com/intel/compute-runtime/releases/download/22.16.22992/intel-opencl-icd-dbgsym_22.16.22992_amd64.ddeb
wget https://github.com/intel/compute-runtime/releases/download/22.16.22992/intel-opencl-icd_22.16.22992_amd64.deb
wget https://github.com/intel/compute-runtime/releases/download/22.16.22992/intel-level-zero-gpu-dbgsym_1.3.22992_amd64.ddeb
wget https://github.com/intel/compute-runtime/releases/download/22.16.22992/intel-level-zero-gpu_1.3.22992_amd64.deb
sudo dpkg -i *.deb
sudo apt update
sudo apt upgrade
sudo -i
sudo reboot now
MAKE SURE TO TURN OFF SECURE BOOT IN BIOS AND BOOT THE NEW KERNEL
b. Commands:
sudo nano /etc/default/grub
Add i915.force_probe=4680 to the line GRUB_CMDLINE_LINUX_DEFAULT line, it will look something like this:
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash i915.force_probe=4680”
SAVE AND EXIT
sudo update-grub
sudo reboot now -
Install Intel drivers
a. Commands:
sudo apt-get install -y gpg-agent wget
wget -qO - https://repositories.intel.com/graphics/intel-graphics.key |
sudo gpg --dearmor --output /usr/share/keyrings/intel-graphics.gpg
echo ‘deb [arch=amd64 signed-by=/usr/share/keyrings/intel-graphics.gpg] https://repositories.intel.com/graphics/ubuntu focal-legacy main’ |
sudo tee /etc/apt/sources.list.d/intel.gpu.focal.list
sudo apt-get update
intel-opencl-icd
intel-level-zero-gpu level-zero
intel-media-va-driver-non-free libmfx1 libmfxgen1 libvpl2stat -c “%G” /dev/dri/render*
groups ${USER}MAKE SURE TO REPLACE ‘USER’ ABOVE WITH THE USER NAME YOU’RE WORKING WITH
CREATE AND EDIT DOCUMENT CALLED “i915.conf” IN “/etc/modprobe.d”
a. Do this by following these directions/commands:
gedit
Add 1 line: options i915 enable_guc=2
Save as i915.conf in modprobe.d
sudo update-initramfs -u
sudo apt update
sudo apt upgrade
sudo reboot now
you should now be able to transcode. all sw vrsions are 1 year old but confirmed working. after update/upgrade, your drivers should update accordingly.
credit/links:
https://tomthegreat.com/blog/setting-up-ubuntu-20-04-lts-for-plex-with-intel-gen-12-cpu/
https://chuckdickey.com/2022/03/plex-hardware-transcoding-with-a-jasper-lake-intel-celeron-n5105-cpu-on-ubuntu-server
https://github.com/intel/compute-runtime/releases/tag/22.16.22992
https://dgpu-docs.intel.com/installation-guides/ubuntu/ubuntu-jammy-arc.html
