Check for Updates Disabled
I’m running PMS on a Windows 10 machine and have found the “Check for Updates” button to be greyed out / disabled. The current install is Version 1.10.1.4602 and is working correctly but I’d like to be able to keep up to date. Is this just an issue of downloading the latest version and then installing over the top? And, if so, then will all my settings etc. be carried forward?
Absolutely LOVE when you click on a Plex link for an answer and you get " Oops! That page doesn’t exist or is private." I am logged in, so why are sooooo many plex links not found? Annoying!
This link was set for a different forum software.
Try holding down your CTRL key while clicking on the link.
