Check if file exists and the required drives are connected
Server Version#: 1.24.5.5173-7000
Player Version#: any
Today I have migrated from a Synology DS218j to DS920+. When I wanted to see how much the performence of Plex had improved, I decided to play something from my tv. Unfortunately, I get the same error message for each video:
"Playback error
Check if the file exists and the required drives are connected"
On my phone I get the message that: “The media is not available. The connected file is not accessible for the server. Check if the file exists and if the required station is accessible.”
I suspect this has something to do with me migrating to a new NAS. Unfortunately, when I add another library, it does not see any of the files from the folder I select.
How do I solve this?
For each of the shared folders which contain your media:
Even though you had previously set permissions for “Plex”,
With DSM 7, you must now grant permission for "System Internal User’ PlexMediaServer to read the shares. ( Control Panel - Shared Folders )
We were forced to change username on DSM 7.
From system to system, the ID number for “PlexMediaServer” is subject to change (because it’s Linux underneath)
