Server Version#: 7.01-42218
Player Version#:1.210-3744
I’m trying to play files from my Syno server, but everything is marked as unavailable. I had to update Plex via Syno Diskstation Manager and I know the Syno version is far outdated compared to what is actually available on the Plex server.
For my Video folder it was already set to allow Plex to read files.
For my Plex folder, it was already set to read/write.
I have “access” to my files via Plex, and I can scan for changes, however nothing is refreshed. This is the error message I constantly receive when I attempt to play a file.
Playback Error
Please check that the file exists and the necessary drive is mounted.
I’ll also add that I downloaded and installed the latest Plex update, overriding Synology’s NAS-compatible Plex DSM download. I don’t know if that is wise. But I’m still coming up with the same error, which is that my media files do not sync, and the ones that are showing in my library do not play:
“Unavailable”
" Playback Error"
“Please check that the file exists and the necessary drive is mounted.”
ERROR - Error opening file '"/volume1/Video2/Movies/Night at the Museum (2006)/Night at the Museum (2006).mp4"' - Permission denied (13)
Your permissions are still screwed up. Still looking at the logs for other files, but if you can give examples of things that wont play or show up that would have been captured during the logs provided I can see if I can find specifics for you.
EDIT: per the FAQ For DSM 7 - Grant permissions for “PlexMediaServer” Where you using the older DSM 6 username of Plex ?
Thanks. I am unable to play literally any files, Movie or TV Show. My current version of Plex is now: 1.28.0.5999-7000
And DSM 7.1-42661
Before I manually installed 1.28.0 my Plex media server was Plex. Since I updated Plex to 1.28.0 I am now using PlexMediaServer. But the only thing I’ve done is grant read/write permission to PlexMediaServer. I haven’t changed any other settings.
Remote Access is not working. Did you see the screenshots I posted above?
