Claiming plex serving after having account recovered
I recently had my account recovered from a hacking attempt and now have no server access. Ive seen on here that i probably need to reclaim my server and i have tried some of the quick fixes but they havent seemed to have worked for me. Does anyone have any input that can help?
Method 2.2: You need to reclaim your server, but don't dare to touch the Windows Registry
what version of notepad are you using? im having trouble trying to save the file as a .reg file.
There is only one version of notepad.exe. The one that comes preinstalled with Windows.
If you can only save a .txt file, simply rename it afterwards and change the file name extension to .reg
This whole process is a bit less confusing if you enable the display of file name extensions in the properties of Windows file explorer.
