Claiming server Issue
Server Version: 1.40.5.8897
Player Version:
Hey there,
I have a problem with claiming the server. I had a working Plex server, but something went wrong, similar to the issue described here: Windows reinstall, No Server Settings, Cannot Make a New Server. I reinstalled the server but could not access the settings, so I added “enableLocalSecurity” in the registry. This made it start working, but I still couldn’t claim the server in the settings even though I relogged in. So, I deleted all files and registry keys, downloaded a brand new installation file, and it needed to add the registry key again. After that, I was in the initial setup, but when I reached “Server Settings,” it threw an error in the log.
I uninstalled VPN, I do not have antivirus.
Can u help me
Logs.zip (195.5 KB)
I am seeing errors connecting to the plex sever. What happens when you visit https://plex.tv/api/v2/pins?strong=true
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<errors>
<error code="1005" message="The request method is not allowed for this endpoint" status="405"/>
</errors>
@ChuckPa I know you are not a Windows guy, but thoughts?
Aug 27, 2024 23:29:15.519 [1228] DEBUG - [com.plexapp.system] HTTP reply status -7, with 0 bytes of content.
Aug 27, 2024 23:29:15.519 [1228] WARN - [com.plexapp.system] Couldn't connect to plug-in, treating as dead.
Aug 27, 2024 23:29:15.519 [1228] DEBUG - Stopping [com.plexapp.system].
Aug 27, 2024 23:29:15.519 [1228] DEBUG - [com.plexapp.system] Killing.
Aug 27, 2024 23:29:15.520 [1228] ERROR - Error parsing content.
Aug 27, 2024 23:29:15.520 [1228] ERROR - Exception caught while updating system agent list: Error parsing file```
Might be a long shot, but I had a similar issue and it turned out to be my DNS settings.
I was using automatic DNS configuration via DHCP, therefore ultimately using my router as the DNS server, which in turn pointed to my service provider’s DNS.
Once I switched to manual DNS configuration and used Cloudflare’s DNS (1.1.1.1), it all went back to working.
As I said, it’s a long shot, but when everything else fails…
I just posted about my own experience:
Good luck there.
