Clearlogo Update?
Server Version#: 1.43.0.10231
Newest beta server mentions clearlogo and square art metadata updates? How can we access this? Tried editing details on a movie and series and didn’t see anything.
It’s updates to the API and the Plex Media Server (backend), nothing (yet?) integrated in Plex’s frontend.
It’ll probably show up with one of the next updates of Plex Web.
Pretty sure its local assets only for this specific update. So, having something like clearlogo.jpg located alone side your media, refreshing the metadata and then the new plex clients will pick it up.
I’ve no way to confirm as the current beta’s have completely broken transcoding for me so they are unusable.
Understood. Thanks!
Confirm over at reddit by a plex employee …
So where to place a clearlogo for a collection?
Plex doesn’t support traditional local assets (posters or backgrounds) for collections so I’d be amazed if they support logos.
This was just mentioned in the TF release notes for the latest beta. I haven’t looked into it yet… I suppose there’ll be an option to manually upload/select logos similar to how you can do for poster/background art… and probably using some API calls.
Yeah, ”Square Art and Clear Logos for Collections and Playlists.” From 2025.30.0 release notes
No update/beta on server side, maybe needs that also….
