Code 422, no remote access (while "Fully accessible outside your network")
Plex Media Server Logs_2020-10-05_07-54-42.zip (3.0 MB)
After @chuckpa fixed the certificate issue new problem has appeared.
The behavior is following:
  • Plex Server claims that “Fully accessible outside your network”
  • The connectivity is confirmed via curl from external machines.
  • Not a single remote device can actually connect.
The only odd thing I can see in the logs is following:
Oct 05, 2020 07:50:42.087 [0x7f70917fa700] DEBUG - HTTP 422 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Please help, it has been many days without remote access.
A bit of an update:
The issue seems to come and go for the Android App and FireTV, while the browser app only works if I allow insecure connections (and sometimes that does not work).
I’ve forwarded all the information to both the Plex.tv and Server teams for them to review when in the office again Monday
That’s the best I can do at this point.
Thank you very much!
I really appreciate your help.
It seems that the issue is fixed for now, the remote access seems to be working.
I am still seeing 422 (when I apply remote access settings) but maybe it is a red herring?
Oct 06, 2020 10:32:16.123 [0x7f70c57fa700] DEBUG - HTTP 422 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Here are the mapping related logs:
Oct 06, 2020 08:50:51.466 [0x7f71017fa700] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Oct 06, 2020 08:51:05.338 [0x7f71017fa700] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Oct 06, 2020 09:50:52.176 [0x7f70c7fff700] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Oct 06, 2020 09:51:05.383 [0x7f70c77fe700] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Oct 06, 2020 10:19:07.322 [0x7f711b639700] DEBUG - MyPlex: reachability check - current mapping state: 'Mapped - Not Published'.
Oct 06, 2020 10:19:07.322 [0x7f711b639700] DEBUG - MyPlex: mapping state set to 'Mapped'.
Oct 06, 2020 10:32:09.886 [0x7f711b639700] DEBUG - MyPlex: reachability check - current mapping state: 'Mapped'.
Oct 06, 2020 10:32:09.886 [0x7f711b639700] DEBUG - MyPlex: mapping state set to 'Mapped'.
Oct 06, 2020 10:32:14.869 [0x7f70c57fa700] DEBUG - MyPlex: stop public ip check and mapping - current mapped state: 'Mapped'.
Oct 06, 2020 10:32:14.869 [0x7f70c57fa700] DEBUG - MyPlex: sendMapping resetting state - previous mapping state: 'Mapped'.
Oct 06, 2020 10:32:14.869 [0x7f70c57fa700] DEBUG - MyPlex: mapping state set to 'Unknown'.
Oct 06, 2020 10:32:16.124 [0x7f70c57fa700] DEBUG - MyPlex: mapping state set to 'Mapped - Publishing'.
Oct 06, 2020 10:32:16.124 [0x7f70c57fa700] DEBUG - MyPlex: mapping state set to 'Unknown'.
Oct 06, 2020 10:32:16.160 [0x7f711a637700] DEBUG - MyPlex: start public ip check and mapping - current mapped state: 'Unknown'.
Oct 06, 2020 10:32:16.160 [0x7f711a637700] DEBUG - MyPlex: mapping state set to 'Not Mapped'.
Oct 06, 2020 10:32:16.160 [0x7f711a637700] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Oct 06, 2020 10:32:29.980 [0x7f7101ffb700] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Oct 06, 2020 10:32:29.980 [0x7f7101ffb700] DEBUG - MyPlex: sendMapping resetting state - previous mapping state: 'Mapped - Not Published'.
Oct 06, 2020 10:32:29.980 [0x7f7101ffb700] DEBUG - MyPlex: mapping state set to 'Unknown'.
Oct 06, 2020 10:32:31.281 [0x7f7101ffb700] DEBUG - MyPlex: mapping state set to 'Mapped - Publishing'.
Oct 06, 2020 10:32:33.576 [0x7f711b639700] DEBUG - MyPlex: reachability check - current mapping state: 'Mapped - Publishing'.
Oct 06, 2020 10:32:33.576 [0x7f711b639700] DEBUG - MyPlex: mapping state set to 'Mapped'.
Thanks a lot!
@SergeiFranco
Thank you for sticking to it and capturing the info. This is valuable information and I’m forwarding to the team now.
Thank you !
