Codec av1
Bonsoir, est ce que ce format AV1 va arriver sur Plex tout prochainement ?
What exactly are you missing?
Playback of AV1 content in a specific app, transcoding of AV1 content with/without hw-acceleration, transcoding to AV1…?
La lecture direct sans conversion Ă  partir des lecteurs Plex sur les applications TV ou Mobile.
Lecture direct avec la détection du codec AV1
If the TV supports hardware playback of AV1 it should be direct playing now without conversion.
Google added a software decoder for AV1 over a year ago. Even if your smartphone does not have AV1 hardware support it likely will direct play AV1 now.
What are the make and model of the devices you use that are not playng AV1?
Bonjour, La marque TV PANASONIC LZ2000E
I’ve moved this to the smart tv section. If there’s indeed a gap on your device, please comment/vote in the linked feature suggestion to help us avoid distracting or cannibalizing votes.
The Panasonic LZ2000E runs a Panasonic-specific OS called “My Home Screen”. Looks like it would be on the Plex “Smart TV” app platform. I did see a Plex on the apps listed on a screenshot in this review. Also I have found this specs listing showing AV1 as supported.
Plex has previously needed to enable AV1 support on a model-by-model basis so likely this one just slipped through and wasn’t seen.
Suite du test avec Tv Panasonic cela ne fonctionne pas avec Codec AV1 et plex cela tourne dans le vide. J’ai fait le tet avec apple TV et plex même résultat codec AV 1 ne passe pas.
Je ne comprends pas le résultat.
There are no Apple TV models that support AV1 in hardware, so it won’t direct play on that device. But since it’s not supported it should be triggering a transcode back on the server and you should be able to see the content transcoded at least. To pursue this issue you would want to supply client logs from the Apple TV and server logs so Plex can see why the transcode is not being done.
That would be an issue with Plex Media Server itself, though. Separate of Plex not working with the AV1 support for your smart TV.
Le plex média serveur est sur un Nas QNAP TVS 951
I couldn’t find a listing for a plain 951. The model 951N and 951X are the same (besides the networking speed) and have an iGPU. It is Intel HD Graphics 610 (Kaby Lake). That will not have any AV1 hardware acceleration support, but it can still potentially decode in software okay. My own system does not have any GPU at all and I can transcode AV1.
So as far as the failure to play transcoded on the Apple TV, we’re still in a place where logs will be needed for Plex to look at and track down what is happening.
Sur le serveur je n’ai pas autorisé le transcodage, sur l’Iphone l’AV1 passe sans problème mais pas sur l’Apple TV.. j’ai activé la transmission des log pour plex
Have you tested this directly (inability to direct-play)? I ask because I regularly test various formats with the new experience clients on Apple TV; my test files direct play:
There’s definitely no transcoding taking place on the server. The new client (and at least Infuse) seem to be able to handle it, regardless of the hardware capabilities.
You disabled transcoding? To be clear, that means checking this box:
Screenshot 2026-04-11 at 14-04-24 Plex
If you did that, it would explain why you can’t play the AV1 on the Apple TV.
It’s decoding in software. An Apple TV is powerful enough (due to using an older cell phone processor) it can handle it that way. Just like many older Android smartphones can play back AV1 now because Google added a software decoder to the system through the Google Play services.
Since this fellow is using the official public Plex client he wouldn’t have the option of using AV1 software decoding if they added it to the TestFlight app or Infuse.
Right, but the statement was that it wouldn’t direct play. Just because it’s happening in software on the Apple TV side doesn’t mean it’s not direct play-capable.
My point is that we can expect the Apple TV to direct play AV1, at least with the new experience clients (I haven’t tested the legacy one). (My Apple TV 4K is the 1st generation one.)
So, @d_ne6, what Plex app version are you running on your Apple TV (and what specific model is it)? Then we can see if this should be working.
Do we know that? I haven’t fully transcoded their side of the conversation yet.
From what I see here, my understanding is it’s pretty hard to get on the Apple TV TestFlight. So I wouldn’t expect he is on anything but the normal public release. Infuse would be something to try now, but really I wish someone from Plex would address the fact his TV’s abilities are being ignored more.
oui fichier AV1 direct par plex sans transcodage cela ne fonctionne pas
Dernière version de l’Apple TV 4K et la dernière mise à jour de Plex sur Apple TV
If you want to make the current public plex app play AV1 files, you can add an updated tvOS profile to your server. This will allow you to direct play, but it will decode in sw on the ATV, so everything may not play smoothly. I have it on mine, but I don’t use AV1 files regularly.
