I’ve had an issue for a little while now and I’m not sure what triggered it or how to resolve it…
When I go to Movies > Collections I only see my Library View.
This means I get all of the same options and Library View and things work as expected but I’m in the “Collections”
I don’t have this issue in my TV Shows.
Is there a way to resolve this without re-creating my Movies Library?
I hear this happens because of a bug in the browser client app. meaning you must go to the plex settings in the browser and reset customizations. This only means you will have to re-pin your libraries to the side bar, it won’t effect your server nor will it delete any existing libraries:
https://support.plex.tv/articles/customizing-plex-web/#:~:text=Reset%20Customization&text=Navigate%20to%20General%20under%20the,Select%20Reset%20Customization
This did work for the Web Version!
Thank you so much.
I tried on the desktop version but same result.
*Hopefully they’ll fix this in a future release
