Thanks for the instructions. I’ve been trying to get a build working for a while. Although I was using QT5.10 and couldn’t get past a build error. Yesterday I went back to QT5.9.4 and it’s been building ok now.
Will spin up another development server and give this a go as well.
I have successfully compiled PlexMediaPlayer 2.8.0.1. Working good so far on RPi2.
I can make this available for a limited time if anyone wants it. This is the community build. This is NOT an official Plex Inc. build and is no in way supported. Use at your own risk.
Tried it today again and now getting another error. I only see people reacting that they build it successfully, How come this is working for all but me?
Was coming here to say that! If the build fails
make clean
Should tidy it up to start again. It did add above though and just manually removed the duplication.
@rolandbird
Thank you for your answer, that worked to start the build again.
Unfortunately i still cant get past the building of QT5.
it stops everytime with the following error:
Done. Made 5310 targets from 1110 files in 18180ms
/home/appiekap653/plex-LibreELEC.tv/build.PlexMediaPlayer-RPi2.arm-8.2.2/qt5-5.9/qtwebengine/src/3rdparty/ninja/ninja -C /home/appiekap653/plex-LibreELEC.tv/build.PlexMediaPlayer-RPi2.arm-8.2.2/qt5-5.9/qtwebengine/src/core/Release QtWebEngineCore
ninja: Entering directory `/home/appiekap653/plex-LibreELEC.tv/build.PlexMediaPlayer-RPi2.arm-8.2.2/qt5-5.9/qtwebengine/src/core/Release’
[80/5869] CXX obj/content/common/common/content_message_generator.o
FAILED: obj/content/common/common/content_message_generator.o
{standard input}: Assembler messages:
{standard input}:432194: Warning: end of file not at end of a line; newline inserted
{standard input}:432321: Error: unknown .loc sub-directive `discriminat’
{standard input}: Error: open CFI at the end of file; missing .cfi_endproc directive
{standard input}:432320: Error: branch out of range
armv7ve-libreelec-linux-gnueabi-g+±6.2.0: internal compiler error: Killed (program cc1plus)
One additional dependency I’ve had to install is g+±multilib. The instructions already mention gcc-multilib but I’ve found g++ is required as well.
sudo apt-get install gcc-multilib g++-multilib
On another note I have compiled another image using qt5.9.4 instead of qt5.9.2. Not sure if this is going to make any difference at all. The default build is a bit sluggish in terms of how the UI responds, but in general if you put aside that issue it’s working really well on the RPi2.
I have succeeded the build.
The problems i had were due not enough memory.
I only stumbled upon one strange thing.
before installing everything it makes some directories and files in the image dir.
in ‘build.PlexMediaPlayer=RPi2.arm-8.2.2/Image/System’ it makes a file called ‘media’
afterwards it wants to copy the directory ‘build.PlexMediaPlayer=RPi2.arm-8.2.2/uchardet-0.0.6/.install_pkg/media’ into ‘build.PlexMediaPlayer=RPi2.arm-8.2.2/Image/System’ which fails with the message cp cannot overwrite non-directory with directory.
I could get around it by starting the build and quickly remove the ‘media’ file by hand before it will copy the directory.
Did anyone else came across this or does it has something to do with a different install script or different system setup?
I haven’t used 2.7.1, but 2.8 is ok. I have been using it for a few days now. The UI does become unresponsive briefly when moving between library categories, and it does take a bit of time to load and display the items within each library. Having said that though the length of time is very similar to the delays on the older 1.x series.
My verdict is that it’s usable. It really needs to cache rather than fetching the library contents each time.
I have the same experience as Rolandbird.
I also had some troubles with playing tv shows.
When you skip back a few minutes the image will go back but wont play anymore.
You have to restart it.
I also had a lot of buffering problems where it would buffer every 2 seconds again.
I haven’t tried it jet on a 1080p tv but on my 720p tv the subtitles are displayed too low on the screen. i’m missing half of the letters.
to reiterate Jacob’s question any planning on posting a fully built image for a pi2/3 ? if there is an issue with storage on github i have a paid github account and a LOT of google storage space… I would be more then happy to host the builds in either place under my account. (i’ll be honest im swamped and don’t have a lot of time to build this myself).
after many failed attempts I was finally able to compile the latest version. Below are the links for anyone who wants to try them. If this is against the rules please delete it or let me know and I will delete it. Thanks.
While running they show openelec base of 8.2 and Qt version 5.9.2
I was holding off on publishing any builds because I didn’t want to support anyone having issues with them.
There’s obviously reasons that Plex hadn’t published them yet.
Good luck using these builds though, just remember to keep an eye out for the official builds. Not sure if the auto updater works for these builds.
Here’s some of my builds. I’m only building the RPi image at the moment. I have a more recent build of the media player with web-client 25-fea08608883bd1. They are built using qt9.5.4 instead of the configured qt9.5.2 - just trying something different.
