Server Version#: PC
Player Version#: Latest Version
Im trying to configure 2 plex servers in the same network and im finding difficulty, i dont know whats the reasons , so the problem is that i have already a Qnap on the same network with ip 192.168.0.102 forward to port 32400 , i added another plex server via pc as its server and gave it an ip of 192.168.0.122 and forward it to 32401 and manuly did it in plex but the 2 servers are conflicting i assume or there is a problem coz they’re not working properly.
and yes im maping my Qnap in the pc as a network drive and then connecting plex to it as another individual plex pass
Not “to”, but “from”.
Your port forwarding setup in your router must look like this:
WAN:32401 → LAN 192.168.0.122:32400
i.e. the external (WAN) port number can change, but the internal (LAN) port number must always be 32400
In the configuration page of this Plex server, under ‘Remote access’, you then have to put the external port number into ‘Manually specify public port’ and tick the checkbox, ofc.
Model : TP- Link Archer C9
Configuring the ip adress in Forwarding —> Virtual Servers —> add New port and ip adress , in my router.
i already did it for my Qnap and its working fine now i want to add another server on the same network , but i get the error i just showed in my previous reply
Inspect any existing port forwardings (or ‘virtual servers’, as TP-Link likes to call them). Delete any which are pointing to the internal IP 192.168.0.122 and the internal poort 32400.
Then set up a new port forwarding.
Service Type: Plex
External Port: 32457 (or any other number in that region)
Internal IP: 192.168.0.122
Internal Port: 32400
Protocol: TCP
Enable
