Can someone explain how this “Agents” section below works, I thought all Agent settings were now typically done at the Library level so a bit confused?
Above is for libraries, that are using legacy/3rd. Party agents only
Ah OK, that isn’t obvious…
Would be good if title was changed from “Agents” to “Legacy Agents” instead with an appropriate note.
