Connection Lost After Viewing
Have an odd issue that has only surfaced recently where I can watch something no worries, but if I finish the show and hit the back button I lose the connection totally to Plex.
I can only continue to hit the back button on the Apple TV to go back to the ATV main screen and then go back into Plex to start it off again.
There is no other way to continue watching if I hit the back button whatsoever.
Am running Verison 0.6 even though there is an update waiting, but that Update doesn’t work as noted in other threads.
Any ideas please?
If you reset your PlexConnect host or update/restart/stop-start PlexConnect itself you will need to exit the hijacked app completely and open the hijacked app again to use PlexConect again which is normal since you reinitiated PlexConnect by doing one of the things stated prior. If this isn’t the case please post a log per the read before posting sticky states.
Thanks but it happens without resetting anything at all. it happens just by watching something, then hitting the Back button and gone, lost.
I’ll get log up.
