Connection refused / Unable to connect to Plex Media Server
I am having some trouble connecting to my Plex Media Sever “all of a sudden”. I have been using it for many years but today it stopped working for no apparent reaseon.
When I try to connect to my plex server from my phone with the Plex App I can see that I am disconnected. If I try to connect from a computer (192.168.1.200:32400/web/) I get connection refused. I can SSH to the computer (anders@192.168.1.200) without any problem and have other applications (eg. Flexget) running that requires internet connectivity and they are all working fine.
If I run “systemctl status plexmediaserver” I get the following output:
plexmediaserver.service - Plex Media Server
   Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
   Active: active (running) since Sat 2019-03-23 07:21:52 CET; 2min 58s ago
  Process: 2507 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPOR
 Main PID: 2511 (sh)
    Tasks: 6 (limit: 4417)
   CGroup: /system.slice/plexmediaserver.service
           ├─2511 /bin/sh -c  PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )"  PLEX_MEDIA_SERVER_INFO_DEVICE=
           └─2529 /usr/lib/plexmediaserver/Plex Media Server
Mar 23 07:21:52 computername systemd[1]: Starting Plex Media Server...
Mar 23 07:21:52 computername systemd[1]: Started Plex Media Server.
If I run “sudo netstat -lnpt” I get the following output:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      1882/smbd
tcp        0      0 0.0.0.0:5901            0.0.0.0:*               LISTEN      1768/Xtightvnc
tcp        0      0 0.0.0.0:8112            0.0.0.0:*               LISTEN      1612/python
tcp        0      0 0.0.0.0:6001            0.0.0.0:*               LISTEN      1768/Xtightvnc
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      1047/systemd-resolv
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1503/sshd
tcp        0      0 0.0.0.0:25              0.0.0.0:*               LISTEN      1864/master
tcp        0      0 0.0.0.0:5050            0.0.0.0:*               LISTEN      2432/python
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      1882/smbd
tcp        0      0 0.0.0.0:58846           0.0.0.0:*               LISTEN      1305/python
tcp        0      0 0.0.0.0:6881            0.0.0.0:*               LISTEN      1305/python
tcp        0      0 127.0.0.1:44579         0.0.0.0:*               LISTEN      2432/python
tcp6       0      0 :::139                  :::*                    LISTEN      1882/smbd
tcp6       0      0 :::22                   :::*                    LISTEN      1503/sshd
tcp6       0      0 :::445                  :::*                    LISTEN      1882/smbd
tcp6       0      0 :::6881                 :::*                    LISTEN      1305/python
“ps aux | grep -i plex*” gives me:
plex      2511  0.0  0.0   4628   872 ?        Ss   07:21   0:00 /bin/sh -c  PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )"  PLEX_MEDIA_SERVER_INFO_DEVICE="PC"  PLEX_MEDIA_SERVER_INFO_MODEL="$(uname -m)"  PLEX_MEDIA_SERVER_INFO_PLATFORM_VERSION="$(grep ^VERSION= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )"  LD_LIBRARY_PATH=/usr/lib/plexmediaserver/lib  "/usr/lib/plexmediaserver/Plex Media Server"
plex      2529  0.0  0.7 402204 28628 ?        Sl   07:21   0:00 /usr/lib/plexmediaserver/Plex Media Server
anders    2654  0.0  0.1  64916  6144 pts/0    T    07:24   0:00 systemctl status plexmediaserver
anders    3787  0.0  0.0  14428  1004 pts/0    S+   07:31   0:00 grep --color=auto -i plex*
Finally, “journalctl -xe | grep -i plex” gives me:
-- Subject: Unit plexmediaserver.service has begun start-up
-- Unit plexmediaserver.service has begun starting up.
Mar 23 07:21:16 toshiban systemd[1]: Started Plex Media Server.
-- Subject: Unit plexmediaserver.service has finished start-up
-- Unit plexmediaserver.service has finished starting up.
Mar 23 07:21:45 toshiban sh[1386]:   what():  Codecs: Initialize: 'boost::filesystem::create_directory: Permission denied: "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/a22632d-2132-linux-x86_64"'
Mar 23 07:21:45 toshiban sh[1386]: ****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.15.2.793-782228f99/PLEX MEDIA SERVER/51d8c4fa-50b5-e18a-2100dc9c-025f1f31.dmp
Mar 23 07:21:47 toshiban systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=134/n/a
Mar 23 07:21:47 toshiban systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Mar 23 07:21:52 toshiban systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Mar 23 07:21:52 toshiban systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 1.
-- Automatic restarting of the unit plexmediaserver.service has been scheduled, as the result for
Mar 23 07:21:52 toshiban systemd[1]: Stopped Plex Media Server.
-- Subject: Unit plexmediaserver.service has finished shutting down
-- Unit plexmediaserver.service has finished shutting down.
Mar 23 07:21:52 toshiban systemd[1]: Starting Plex Media Server...
Mar 23 07:21:52 toshiban systemd[1]: Started Plex Media Server.
If I look in “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports” I cannot find the directory 1.15.2.793-782228f99. Attached you will find Plex Media Server.log.
Server Version#: Unable to find
OS: Ubuntu Server#: 18:04
Plex Media Server.log (3.7 MB)
Can someone pleae help me to resolved this or point me in the right direction?
Best regards
Anders
You have permission issues inside the Plex data directories themselves.
Did you customize the username Plex runs as?
If not, with plex stopped,
sudo chown -R plex:plex /var/lib/plexmediaserver`
This will clear up this error (which occured right before the crash.
Thank you very much! I ran the following commands and can now connect to Plex Media Server!
service plexmediaserver stop
service plexmediaserver start
I did not change the permissions or custimized in any way.
Best regards
Anders
