Connexion problem
Server Version#: 1.18.5.2309-f5213a238
Player Version#: FireFox 76.0.1 / Apple TV Latest version
Hi everyone !
I use Plex Media Server on a Synology NAS (latest version updated), and I use it on Apple TV.
Until there, everything is going right.
But if I want to manage my libraries, when I’m supposed to connect to my account, I get that message : an error occured while registering.
I’m sure of my login / Password, because I could create a topic on that forum :slight_smile:
Here are the steps I use to do :
I connect on my Synology NAS 192.168.1.10:5000
I click on the Plex Media Server icon, which redirects me to http://192.168.1.10:32400/web/index.html, and then to https://app.plex.tv/auth/#!?clientID= etc.
Here my mail adress and password are asked.
I fill them, and I get my error message.
The only solution I have to solve this until now is to stop the server on the NAS and restart it.
Then I can login to Plex Server.
Does someone have the same problem ?
Thank you for your help !
Kind regards
Thank you, that was a fast reply ! :slight_smile:
I did what you told me, I had to reclaim the server, I was asked to confirm the 6 libraries I already had before, but now the servers appears unavailable.
I restarted the server once, and still have the same problem.
I removed the new xml file which was created, renamed the Preferences.xml.old
file in Preferences.xml and I have my libraries back.
I wonder if I have a cookies problem here finally, because it works right now, but if I close FireFox, the next time I’ll have to connect, it’ll fail. It’s a strange issue
I tried with Chrome too, same problem.
What I did in my NAS network configuration was to configure it with DHCP, with an IP reservation on my router, because I often had the gateway disapeared, with no reasons, after some days.
Since my network configuration is stable, the problem seems to be solved !
Thank you for your help and have a nice day ! :slight_smile:
