Constant 10%+ cpu usage
Server Version#: 1.32.7.7571 (64 bit)
Windows 10
The last few days PMS have been using 10% or more cpu doing nothing.
Tried updating og rolling back update, nothing helps.
When PMS is restarted, it goes away for a short time.
Read other topics stating the same, but no solution.
Can you post links to the other issues your following?
What CPU?
Are you transcoding with CPU or GPU?
Do you have any scheduled tasks running during the times it’s using CPU?
Just hoping to narrow this down.
i7-10700
RTX A2000 6g for TC
No scheduled tasks running.
It’s constant 10%+ cpu usage. As stated if i restart, it goes away for a few minutes.
PMS is doing absolutely nothing.
It has been a day since posting, and it is no longer a problem.
Idle cpu usage now is 0-0,1%.most of the time.
I have no idea what caused the high usage.
And the problem is back, i dont get it…
I have the same problem, PMS constantly using 20%-25% of cpu doing nothing.
Once restarted, goes away for some time but eventually comes back.
Docker version of PMS (version 4.108.0), installed on Unraid OS (version 6.12.4).
cpu i5-3470 CPU @ 3.20GHz
Log constantly says:
[Req#1efc5/Transcode/2055115d-7d5d-427a-a19a-081803000fb2/335e41f9-312e-4ce6-8b03-84e37eb4b4e0] Error while decoding stream #0:1: I/O error
[Req#1f03e/Transcode/2055115d-7d5d-427a-a19a-081803000fb2/335e41f9-312e-4ce6-8b03-84e37eb4b4e0] [eac3_eae @ 0x1532c26f9dc0] error reading output: -5 (I/O error)
[Req#1f06c/Transcode/2055115d-7d5d-427a-a19a-081803000fb2/335e41f9-312e-4ce6-8b03-84e37eb4b4e0] [eac3_eae @ 0x1532c26f9dc0] EAE timeout! EAE not running, or wrong folder? Could not read ‘/tmp/pms-677108b5-5f03-479b-a25c-444db152d53e/EasyAudioEncoder/Convert to WAV (to 8ch or less)/2055115d-7d5d-427a-a19a-081803000fb2_850-0-1449.wav’
Anyone?
