Please see the attached
Thanks.
Logs.zip (6.8 MB)
THank you for the logs.
When is the last time the database was optimized ?
I ask because 5 seconds to retrieve 13 items shows it’s in bad shape.
13 items should require about 10ms, not 5000ms.
Nov 11, 2021 17:10:24.333 [0x72857d48] DEBUG - Completed: [127.0.0.1:36299] 200 GET /library/metadata/27439/tree (18 live) GZIP 10919ms 1695 bytes
Nov 11, 2021 17:10:24.464 [0x70f1ed48] DEBUG - Setting container serialization range to [0, -1] (total=-1)
Nov 11, 2021 17:10:24.638 [0x7334fd48] DEBUG - Jobs: '/volume1/@appstore/PlexMediaServer/Plex Media Scanner' exit code for process 2955 is 0 (success)
Nov 11, 2021 17:10:25.248 [0x70efbd48] DEBUG - Request: [127.0.0.1:36311 (Loopback)] GET /services/lyricfind/search?reqtype=default&searchtype=track&limit=100&output=json&artist=Bobby%20Short&track=Where%20Have%20You%20Been (17 live) GZIP Signed-in Token (kido25@protonmail.com)
Nov 11, 2021 17:10:25.249 [0x71167d48] WARN - SLOW QUERY: It took 5000.000000 ms to retrieve 13 items.
Nov 11, 2021 17:10:25.560 [0x715e0d48] DEBUG - Loading information from media bundle for part ID 26014 from "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Media/localhost/9/abfafa54e2ac9ccfa5aba0a5aa91364be5619c4.bundle/Contents"
Nov 11, 2021 17:10:25.562 [0x71008d48] DEBUG - HTTP/1.1 (13.8s) 200 response from GET http://127.0.0.1:44200/:/plugins/com.plexapp.agents.localmedia/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo2CnMyCnh4czQKbGFuZ2IwczYKbWFudWFsYjBzNwpwcmltYXJ5aTAKczcKdmVyc2lvbnIxCnM2Cmt3YXJnc3M1CkFsYnVtczEwCm1lZGlhX3R5cGU1CnM1CjI3NDM4czgKcGFyZW50SURzMzcKcGxleDovL2FsYnVtLzVkMDdjM2YwNDAzYzY0MDI5MDliNDEyZnM0Cmd1aWRiMXM1CmZvcmNlczIwCnR2LnBsZXguYWdlbnRzLm11c2ljczEzCnByaW1hcnlfYWdlbnRzNQoyNzQzOXMyCmlkcjAK
Nov 11, 2021 17:10:25.562 [0x71008d48] DEBUG - [com.plexapp.agents.localmedia] HTTP reply status 200, with 600 bytes of content.
Nov 11, 2021 17:10:25.563 [0x713bad48] DEBUG - Loading information from media bundle for part ID 26064 from "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Media/localhost/5/426360d177dbf245df3b251c262927d9cf3cff3.bundle/Contents"
Are there any other apps running on the NAS?
Nov 11, 2021 17:10:28.302 [0x71bb8d48] DEBUG - Request: [127.0.0.1:36309 (Loopback)] GET /library/changestamp (13 live) GZIP Signed-in Token (kido25@protonmail.com)
Nov 11, 2021 17:10:28.302 [0x71e08d48] WARN - Took too long (5.480000 seconds) to start a transaction on ../Library/MetadataItem.cpp:3819
Nov 11, 2021 17:10:28.303 [0x71e08d48] WARN - Transaction that was running was started on thread 0x715e0d48 at ../Library/MetadataItem.cpp:7203
Would like to say thanks for all your help. I ended up upgrading the NAS drive and that’s solved all my problems. Don’t think my other drive was powerful enough to keep up with my demands.
