Constant high CPU load Synology
Hello together,
I have a problem with my Plex Media server, natively installed on my Synology DS1819+, where my plex Transcoder process produces 25% cpu load between 2 am and 7 pm.
I don’t know why, maybe someone could have a look at my server logs.
I tried updating multiple times, but the problem persits since several months.
Server Version#:1.28.0.5999-7000
plex logs.zip (3.9 MB)
In your Scheduled Tasks,
1 CPU core will run to perform the analysis & maintenance options you have.
On a Quad core CPU, this is 25% CPU load.
It’s normal to see this.
If you don’t like it, start turning off some of the maintenance options.
2am → 7pm does sound like your hours aren’t set correctly. You might also want to check that.
PS: You hit “Reply” before the upload completed. The logs didn’t attach
Hello,
I can understand the 25% CPU load, but maintenance is set to start at 2 am and stop at 5 am, so why is the cpu load high after 5 am?
Another thing is, normally I can see running tasks in the Dashboard, but these I can just see in the logs.
PS: Logs are now uploaded, was just a formatting mistake
