Server Version#: 1.43.5.11079-b3b13e506
Player Version#: 1.115.0.426-4e960a1d
I’m having an issue where one season of a TV show I have has disappeared from my library, and I’m unable to get it back. I had to move an episode because it was a special that wasn’t “officially” part of the season, and when I did that, the entire season disappeared. The files are all still there, as they were before, but I can’t get Plex to reindex them and add them back in to the library.
Does anyone have any suggestions on things I can try or do to get the files back?
Have you tried doing a “Refresh Metadata”? What was the show/season/special. I’ll see if I can replicate it. Do you default to TVDB or TMDB episode ordering?
I moved the file to a “Specials” folder, and then renamed all the subsequent ones to adjust them. So, Episode 1 was the special, but what the actual first episode was (originally) episode 2, so the shows were off from what Plex thought they were (the library was correct, but the files were wrong)… since the special wasn’t accounted for in the library’s season list, it listed an extra episode with no library match. So, basically, I moved Ep 1 to the new folder, then renamed Ep 2 to Ep 1, Ep 3 to Ep 2, and so forth, so those changes should have been invisible to Plex, and the extra episode should have fallen off. When I was done, Plex said none of the files were playable. I rescanned the library and it marked every file in that folder as offline. I rescanned again, and the entire season was removed from my library. The files are still there and I can open them in any media player and they play fine.
In this case, this folder and media files are located on the server itself. I’ve checked the Windows permissions and they all appear to be the same. I reset them to match what the other folders have for good measure – still no dice.
So I don’t run Plex on Windows, so unfamiliar with what can happen. I’d suggest stopping ple, move the show out of your library, then restarting plex to get fresh logs. Then move you show back into the library, let plex do it’s thing, the post the server log
Have you done the plex dance with the files you have been renaming/moving? May help plex properly recognize them again.
Also, can you share screenshots of the folder with the file names so we can see how they’re named and how your folders are structured? Hard to follow the description, sorry.
The Plex Dance didn’t do anything. I’ve attached a screenshot with the list of file names, which has worked for every TV show I have on Plex, including all the other seasons of The West Wing, but I can’t, for some reason, get this season back. Remember, this was listed until I moved one episode to another folder, and then renamed all the remaing one to match their actual episode number.
Just because it worked, doesn’t mean it was right and always will work. You need to fix your naming. Episodes are likely getting mixed as duplicates. Fix the naming, and plex dance the files again.
Here’s how West Wing should be named. You can leave off the {tvdb-72521}.
The West Wing (1999) {tvdb-72521} / Season XX / The West Wing (1999) - SXXEXX.ext
I feel that might be a
Video libraries won’t detect “mp3” files as videos… based on their size, I assume it’s videos with bad names (file extension not matching the file type).
That being said… veeejay’s comment on file naming is also relevant. You can get lucky with bad file names, until you no longer do – it’s better to follow the naming schema.
