CONTINUE PLAYING (duplicate ??)
why is there two of the same continue playing video showing ?!
Do you have two versions of that movie in two different libraries? e.g. a 3D and a non-3D version or something similar?
No, this has been happening for all my movies since the last update :frowning:
Iake a look at the mediainfo of this movie.
Does it show two files or the same file twice?
actually yes I just noticed that, I have 3D versions of most my movie collection! how can I fix this or is this a known issue ?
I think it already has been reported.
Which version of the Server are you using?
Are you using the local version of the Web app or the hosted version?
I dont know! how do I check ?
I gave you a link above.
The server version can be seen under Settings - Server - General
I am on Version 1.1.3.2700 & it is a local version ??
so is this is a known issue that is being looked into ?
It is my understanding that this is known, already.
Right now there is nothing you can do about it, except this:
Put all your 3D movies into a separate library and use “the other” metadata agent for it.
e.g. if your normal movie library uses ‘Plex Movie’ then the 3D library may use ‘TheMovieDatabase’
thank you very much for your help & I will be looking forward to the fix
