Hi I have a Plex server that only has two videos loaded at a time. At work someone watches these videos after a training session, then they are deleted and the next videos are uploaded.
If you look at the screen shot, in the Home screen, there are two continue watching rows, showing the same.
How can I remove the duplicated row, so that Continue watching only shows once on the home screen.
The Library settings are to only show Continue watching on the Home screen.
No other library contains the folder of this library.
Thank you Otto,
I don’t see debug from the path you gave. Did you mean Reset Customisation, from Settings - ‘Show Advance’ - Plex Web - ‘Reset Customisation’?
I have reset from
Manage - Libraries - Resetting Customisations. no change.
