Looks like a bit of DB corruption today sir, and a 404 when your system tried to get the HEVC codec. You might also check if you or your ISP instigated some sort of double NAT.
in "Plex Media Server.log"
Oct 05, 2019 12:16:02.987 [0x70000566f000] ERROR - SQLITE3:0x7000053df180, 11, database corruption at line 60663 of [fc49f556e4]
Oct 05, 2019 12:16:02.987 [0x70000566f000] ERROR - SQLITE3:0x7000053df180, 11, database disk image is malformed
Oct 05, 2019 12:16:02.988 [0x70000566f000] ERROR - SQLITE3:0x7000053df180, 11, database corruption at line 60663 of [fc49f556e4]
Oct 05, 2019 12:16:02.988 [0x70000566f000] ERROR - SQLITE3:0x7000053df180, 11, database disk image is malformed
Oct 05, 2019 12:16:02.989 [0x70000566f000] ERROR - Gracenote: Playlist locale error -1870658241 (CorruptDB: A database disk image is malformed)
Oct 05, 2019 12:16:02.991 [0x70000566f000] ERROR - SQLITE3:0x7000053df180, 11, database corruption at line 60663 of [fc49f556e4]
Oct 05, 2019 12:16:02.991 [0x70000566f000] ERROR - SQLITE3:0x7000053df180, 11, database disk image is malformed
Oct 05, 2019 12:16:02.992 [0x70000566f000] ERROR - SQLITE3:0x7000053df180, 11, database disk image is malformed
Oct 05, 2019 12:16:02.992 [0x70000566f000] ERROR - Gracenote: Music locale error -1870658241 (CorruptDB: A database disk image is malformed)
Oct 05, 2019 12:16:31.762 [0x700005e1c000] ERROR - MyPlex: mapping failed due to potential double NAT configuration
Oct 05, 2019 12:17:57.564 [0x700005257000] INFO - CodecManager: obtaining decoder 'hevc'
Oct 05, 2019 12:17:57.567 [0x700005257000] DEBUG - Downloading document https://plex.tv/api/codecs/hevc_decoder?build=darwin-x86_64&deviceId=bf73b8a1-6ce7-443c-9ed6-d93459299a61&oldestPreviousVersion=legacy&version=79d11e7-1182
Oct 05, 2019 12:17:57.568 [0x700005257000] DEBUG - HTTP requesting GET https://plex.tv/api/codecs/hevc_decoder?build=darwin-x86_64&deviceId=bf73b8a1-6ce7-443c-9ed6-d93459299a61&oldestPreviousVersion=legacy&version=79d11e7-1182
Oct 05, 2019 12:17:58.512 [0x700005257000] DEBUG - HTTP 404 response from GET https://plex.tv/api/codecs/hevc_decoder?build=darwin-x86_64&deviceId=bf73b8a1-6ce7-443c-9ed6-d93459299a61&oldestPreviousVersion=legacy&version=79d11e7-1182
Oct 05, 2019 12:17:58.513 [0x700005257000] DEBUG - Caching document https://plex.tv/api/codecs/hevc_decoder?build=darwin-x86_64&deviceId=bf73b8a1-6ce7-443c-9ed6-d93459299a61&oldestPreviousVersion=legacy&version=79d11e7-1182 as 70c718a0550d3ebde637e6fa63ffbde100ec88c4
Oct 05, 2019 12:17:58.513 [0x700005257000] ERROR - downloadContainer: expected MediaContainer element, found Response
Oct 05, 2019 12:17:58.513 [0x700005257000] ERROR - Codecs: Failed to download XML for codec 'hevc_decoder'
Oct 05, 2019 12:17:58.514 [0x700005257000] ERROR - Error configuring transcoder: Decoder install failed: hevc
On High Sierra, I’ve had PMS-1.15 thru 1.18 working well. May I ask how you decided to pin the version you’re running at 1.4.3? Just curious.
As far as the SQLITE3 errors in that one db, you can investigate as this article shows:
And the HTTP 404 response, Not Found, the browser was able to communicate with plex.tv, but the server could not find what was requested.
Other than that, how’s your day?
