Conversion Failed. The transcoder exited due to an error
Getting this message for the past 3 nights or so…
I haven’t changed anything as far as I know… It just started happening… I can sometimes get a good 5-10 minutes into a show (live tv) before it craps out… All recorded shows seem to fail due to the same transcoder error…
Log files attached (only included the ones where the dates/times seemed to be recent)… Last crash was around 5:48-5:49 or so… (recent.zip (263.4 KB)
Thanks in advance for any help… This is all new to me and has been happening very frequently the past 3 days… I just got enough time to sit down and attach the logs and write this.
Please help…
I’m running Version 1.13.5.5291
And another log (I turned on verbose logging…
This time I was just watching live TV on the computer and not through ROKU…
The same error happened at 6:13pm and there seems to be mention of it in the logs but its all greek to me…
plexlogs.zip (52.8 KB)
Are you using Windows 10 version 1803?
Yes I have been…
Check out this thread…you need to update your windows install with a specific patch
