Server Version#: 1.18.9.2578
Player Version#: Latest Android TV version
I have PMS running in docker and multiple users are linked and using it. I want to copy that server locally, so I can watch my content across my local wire.
I copied my docker script, the entire config folder, and remapped my volumes to the local folders on my system. The end result was a perfect clone. I don’t want a perfect clone. I want a second server with the same data.
I tried to just rename the copied server, but it doesn’t work. Starting both servers causes one or the other to be unreachable by the clients. I also tried using different claim codes. That did nothing.
Is there some way I can modify my copied server so that it is identified as a unique server?
