So I have a Plex server hosted with Hetzner which I share with my family and friends, but I have decided to duplicate it and set it up on a Raspberry Pi4 for me to use exclusively, as I direct play everything.
I successfully duped the server, but the problem I have is that if the 2nd server (Baby Kong) is running, I can no longer see the 1st server (King Kong) The second I disconnect or turn off remote access to Baby Kong, King Kong reappears in Plex WebApp.
Does anyone have any idea what I need to change or do, to have both servers working at once?
Cheers
Sounds you slipped in a copy of a configuration file that refers to the same machine identifier as your King(?) Kong server – resulting in Plex considering those to be the same server (despite different names)?!
See the last bullet point from the related Linux Tips - #7 by ChuckPa post:
Cloning from one to another:
- Make a backup image
- Transport it to the new system
- Restore the image
- Remember to decommission (delete) the old
Preferences.xml file else you’ll have two servers with the same name and ID.
You sir, are a legend. That was exactly what I had done
and thanks for the link to the linux tips page. I’d not seen it before
Cheers
