Copy files to Media Server after re-installation and lost Reg Key
Server Version#:
Hello. I reset my computer without backing up the files before. In my C disk i had my reg key and both Plex and Plex Media Server.
In Plex media Server you can go to settings and choose which catalogue you want to save your settings. I had that folder on my D-drive. So i still have those files.
Is there at way to restore or use my saved configurations? And how?
I have a PC with Windows 10.
If you’re seeing an option inside Plex to move the server’s data directory, you absolutely need to upgrade your server!!
As for how to point to an existing data directory, this is technically similar to moving the data directory to a new location:
